Script brings error if used twice
I want to get a block with attributes to my drawings, but the code makes some trouble.
If I run the script for the 1st time, it works, but if I delete the block and purge Blocks from the drawing, so the drawing seems to be new, I get an error, when I rerun the script: calling method SetObjectId of interface |Acadbaseobject failed
I can't use the code twice in a file (if the block is deleted & purged), but I can't find an error.
Last week I typed the whole code to a new dvb-file (character by character) and it worked many times?
Today I opened my file, and again - it only worked once.
Can anybody give me a tipp or advice what's wrong?
The Code:
Sub Create_Block_w_Attribute()
' Define the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0
    insertionPnt(1) = 0
    insertionPnt(2) = 0
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "T-X-RE")
' Add attributes to the block
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt1 As String
    Dim prompt2 As String
    Dim prompt3 As String
    Dim prompt4 As String
    Dim insertionPoint1(0 To 2) As Double
    Dim insertionPoint2(0 To 2) As Double
    Dim insertionPoint3(0 To 2) As Double
    Dim insertionPoint4(0 To 2) As Double
    Dim tag1 As String
    Dim tag2 As String
    Dim tag3 As String
    Dim tag4 As String
    Dim value As String
    height = 3.5
    mode = acAttributeModeVerify
    prompt1 = "X"
    prompt2 = "Y"
    prompt3 = "Z"
    prompt4 = "Weight"
    insertionPoint1(0) = 30.5: insertionPoint1(1) = 29: insertionPoint1(2) = 0
    insertionPoint2(0) = 30.5: insertionPoint2(1) = 21.5: insertionPoint2(2) = 0
    insertionPoint3(0) = 30.5: insertionPoint3(1) = 14: insertionPoint3(2) = 0
    insertionPoint4(0) = 30.5: insertionPoint4(1) = 4: insertionPoint4(2) = 0
    tag1 = "T-X"
    tag2 = "T-Y"
    tag3 = "T-Z"
    tag4 = "T-Weight"
    value = "0.000"
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt1, insertionPoint1, tag1, value)
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt2, insertionPoint2, tag2, value)
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt3, insertionPoint3, tag3, value)
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt4, insertionPoint4, tag4, value)
' Insert the block, creating a block reference and an attribute reference
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 0
    insertionPnt(1) = 0
    insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "T-X-RE", 1#, 1#, 1#, 0)
End Sub
Thanks and kind regards
BestFriendCZ
hi
i tested your code and it works correct(ACAD2017). I didn't find any problem here.
Thanks a lot for testing.
Yesterday and today it worked on my PC without any error-message too 🙂
kind regards
