ScaleEntity Method
ScaleEntity Method
dgleason
ScaleEntity Method
dgleason
Does anyone know what the arguments are for the polyline ScaleEntity method... ie. objPline.ScaleEntity (?,?,?)
Dave Gleason
From the Help file:BasePoint, Variant (three-element array of doubles); ScaleFactor,Double. Also, AutoComplete should give you this info. Just type the method, and a space and they should pop up. -Ed
dgleason
Thank you.. I got it. Some times when I have obj's defined for ACAD obj items the auto complete doesn't show what to put. (This is what was happening with the scaling) I just kept doing it until it worked, then I saw your reply.
so thanks.
Do you know how to trim the ends of a line that is between two closed boundaries... (Picture a circle and then concentric circle inside the first. Suppose the larger circle is hatched, and then the hatch is exploded into polys.) How can I trim the edges of the polys that are outside of the smaller circle, but inside of the larger circle. I want to do this using some kind of cool vb / autocad... method. I am doing it know using the scaling, but it really only works for rectangle of closed polys with sharp edges not anything with a curve. I have played a little with sending trim commands to the command line, but I really don't like that so much???...
Dave
Take a look at the IntersectWith method, then modify the startpoint and
endpoint of your line to suit.
-Josh
> saw your reply.
> so thanks.
> that so much???...
> Thanks
> Dave
Dave
Try this way
Sub
size=3>objPline
Dim objP As AcadPolyline
Dim basePoint(0 To
2) As Double
Dim scalefactor As Double
    basePoint(0) =
0: basePoint(1) = 0: basePoint(2) = 0
    scalefactor =
5
For Each objP In
ThisDrawing.ModelSpace
 objP.ScaleEntity basePoint,
scalefactor
  objP.Update
 Next
objP
End Sub
Does
Dave Gleason
