Save Method 2007 - only saves to 2007
The Document.Save method only saves to 2007 dwg files - this makes all add-ons and external programs that use it disregard your default saveas setting.
You can select what version to save to if you use the Document.SaveAs method instead, but why doesn't the save method just check the registry value for that default save setting & use it to determine to which version the dwg must be saved? I mean, why is the setting there, why not use it for all instances, not just the qsave command?
The Save method should use whatever you have set in the Preferences dialog
Open|Save tab.
wrote in message news:5428256@discussion.autodesk.com...
setting.
yes that's true, the save method will use whatever is set in the options
dialog box for the file format.
"Joe Sutphin" wrote in message
news:5430098@discussion.autodesk.com...
Open|Save tab.
setting.
Thanks Bob, I appreciate the confirmation.
Joe ...
"Bob" wrote in message
news:5430228@discussion.autodesk.com...
Open|Save tab.
setting.
Sorry, but I can "UN"confirm your confirmation.
I've got Save As in Tools-->Options-->Open and Save set to: AutoCAD 2004/LT2004
Type "VBASTMT ActiveDocument.Save" at the command line.
The resulting file is a 2007 file, checked it using a 2006 autocad - tells me it's an incompatible version. Opened it in Notepad: the type code in the file reads AC1021 instead of AC1018.
So, NO THE SAVE METHOD IGNORES YOUR SETTING.
It appears there is a bug in AutoCAD 2007 and later versions.
If your file format is set to AutoCAD 2004 DWG it gets ignored and is saved
to 2007.
However, if it is set to AutoCAD 2000 DWG then your document is saved as
2000 which is the way it should work.
I did not check all of the settings but this should alert users to make sure
they are getting documents saved in the file format they wish [with the
exception of 2004].
Of course if you're using AutoCAD 2006 your file format is 2004 by default.
Also, having the preference set to AutoCAD 2000 DWG does save to 2000.
Joe ...
wrote in message news:5431117@discussion.autodesk.com...
2004/LT2004
thanks joe for pointing out the bug, i had only tested it saving to 2000
which you pointed out works.
news:5431309@discussion.autodesk.com...
to 2007.
exception of 2004].
Joe ...
2004/LT2004
