Sample code to read/write XML
Does anyone have VB sample code to read/write XML files?
I know something about reading XML files bu am not sure how to go about
writing (creating) one except that I know what data I need to represent in
XML.
Any help is appreciated.
Regards
Rakesh
An XML file is just a plain old text file, but with tags describing the data. There are plenty of examples in these forums and in AutoCAD's help on how to read/write to files. HTH.
Bryan
I'm just getting started in XML myself, and it takes some figuring out, but
here are some samples of what I've done so far. The function
"tl_xml_stylemaster" reads the name of an ADT project style master folder
out of the project XML file. The function "tl_xml_getlevs" lists the levels
in the project. The variable filnam represents the name of an XML file.
You need to include a reference in your project to a Microsoft XML parser
(get it from Microsoft if it's not already on your computer). I recently
noticed that Autodesk also provides an XML editing tool, and that may be
better, but I haven't looked into it.
Hope this helps. If you need more info, I suggest the book "XML for Dummies"
and the Microsoft XML online help.
Public Function tl_xml_getstylemaster(filnam as string) As String
Dim msdom As DOMDocument
Dim Masterfile As String
On Error GoTo Handler
Set msdom = CreateObject("MSXML.DOMDocument")
msdom.Load (filnam)
msdom.async = False
tl_xml_getstylemaster =
msdom.selectSingleNode("//Project/Standards/AECStandards/File/Path").Text
GoTo Egress
Handler:
MsgBox Err.number & " " & Err.Description
Err.Clear
Egress:
Set msdom = Nothing
End Function
Public Function tl_xml_getlevs(filnam As String) As Variant
Dim levs As IXMLDOMNodeList
Dim lev As IXMLDOMNode
Dim cnt, cnt1 As Integer
With msdom
.Load (filnam)
.async = False
Set levs = .selectSingleNode("Project").selectNodes("Level")
End With
Dim levdat() As String
With levs
ReDim levdat(.Length - 1, 5)
For cnt = 0 To .Length - 1
Set lev = .Item(cnt)
For cnt1 = 0 To lev.Attributes.Length - 1
levdat(cnt, cnt1) = lev.Attributes(cnt1).Text
Next cnt1
Next cnt
End With
tl_xml_getlevs = levdat
GoTo Egress
Handler:
Err.Clear
Egress:
Set levs = Nothing: Set lev = Nothing
Set msdom = Nothing
End Function
"Rakesh Rao" wrote in message
news:5104610@discussion.autodesk.com...
XML.
Regards
Rakesh
