Running action recorded command through VBA
So I have multiple rectangles in a single dwg.  I want to copy one rectangle based on user input.  For example I prompt the user for width and length and it copies that specific rectangle.  I know how to get the user input and i can get the rectangle copied.  My problem is the command I use to do it.  I recorded an action recording in autocad called "1836CPY" which copies the 18" x 36" rectangle in my dwg.  I call it in my vba code as you see below:
ThisDrawing.SendCommand "COPY1836" & vbCr
It works flawlessly, the only problem is after I run this code once that line seems to make it to where the vba never stops running.  I can't hit stop and I can't edit my code.  I can't even hit ctrl + break to stop the code.  the vba editor is just frozen, like it is running indefinitely.  I know sendcommand is not ideal but it works very well with copying what rectangle I need.  Please help!
grobnik
Hi @Anonymous,
I'm still working on code I posted some days ago, in reply to your post with the same issue more or less, but I guess you already have a code.
So, in order to help you with your code COPY1836 or similar without seeing it seems a little hard to help you.
I'm suggesting to share your code and a sample dwg too, if you need more help from others.
However there should be a function for copying objects but I'm finding some issue and I don't know why, this is the reason because I did not reply yet to your post.
As explained before you have the collection of objects inside your rectangle (polyline) (ssetObj), copied in an array sourceEnts, create a new document Set DOC1 = Documents.Add and next step should be copy the array contents into new document retObjects = DOC0.CopyObjects(sourceEnts, Doc1MSpace), but nothing happen in my case, array contents it's filled, but retObject it's empty and nothing will be transferred to new doc.
In any case now I understand you want to copy only rectangle shape and not eventually contents.
Dim sourceEnts()
ReDim sourceEnts(ssetObj.Count - 1)
For i = 0 To ssetObj.Count - 1
    Set sourceEnts(i) = ssetObj(i)
Next
'' you must cache the source document here, because
'' documents.add will change our thisdrawing context
Dim DOC0 As AcadDocument
Set DOC0 = ThisDrawing.Application.ActiveDocument
Dim Doc1MSpace As AcadModelSpace
Dim DOC1 As AcadDocument
Set Doc1MSpace = DOC1.ModelSpace
'' copy the source entities into destination modelspace
'destEnts = objSource.CopyObjects(sourceEnts, objDest.ModelSpace)
Done:
'' clean up selection set
ssetObj.Delete
