Running a script (scr) file in a VBA program
I'd like to include a script command in an AutoCAD VBA program. The program opens a new drawing file, runs a script file, and then saves the drawing. The script file, in this case, is a 3dmesh script file (3dmesh command with M & N values and xyz coordinate triplets in a scr text file).
I'd like to "run" the script file as a step in the VBA program, but I don't know the right syntax. I've tried a number of different command syntax formats.
If the script file name is "3dmesh.scr" what is the right VBA code/command to include in the VBA program to run the script file?
Thanks in advance for the feedback.
Tim Barbour
timbar@att.net
Hi Tim,
There will be a way of using Sendcommand to run the script, but as by
default VBA will continue to run while the script program runs, you will
need to take steps to ensure that no VBA code runs while the script is
running (ie in the simplest case, calling the script is the last thing a
calling function does).
Laurie Comerford
CADApps
www.cadapps.com.au
"timbar" wrote in message
news:f1967a6.-1@WebX.maYIadrTaRb...
formats.
> Tim Barbour
> timbar@att.net
Hi Laurie,
Your advise is right on. I'm just learning AutoCAD VBA. It's similar to other VB scripting languages I've used. I don't know all the syntax, but learn what I need, as I go.
Now that I understand how the SendCommand can be used to execute a _script command (or other command-line commands), I think I can implement it, and place the script run within the broader VBA run (as you advised), so it'll work the way I want.
As mentioned previously, my task is to write a VBA program to open a new drawing, run a script (now with the VBA SendCommand "script" command), and then save and close the drawing. The script I'm trying to run is a "3dmesh command" script.
Since I'm not totally up to speed with VBA, I'm still running into some syntax problems. What I need to know (hopefully you can help), is:
How can I replace the "Select Script File" dialog I get when I type in "script" on the AutoCad command line with an appropriate VBA command line. The VBA command line I'm using is:
ThisDrawing.SendCommand "_script" & vbCr & filenameSCR & vbCr
where the variable filenameSCR is
filenameSCR = path15 + foldername + "\" + fileName + ".scr"
and where the path, foldername and filename variables are pointers to the script file location on my computer hard drive.
My folder and file names have "spaces" in the name string, so the script command (when executed from the command line) rejects the names because of the spaces. The script command reads the folder and file names incorrectly in pieces.
The "Select Script File" dialog doesn't have this problem. Using this dialog, and highlighting the desired (scr) file, and opening the selected file works OK (even with the spaces included in the name). It's this type of functionality that I'd like to replicate with VBA.
I've come across some AutoCAD Help info on VBA file selection for opening files (in my particular case, using the Select Script File dialog), but I've lost the "help" for the moment.
This may be a new forum question, but since you were right on the first time, I thought I'd ask you about -
how to select files to open (in this case a script file) in VBA using the "select file dialog" approach.
I hope I've presented my question clearly. Thanks for your previous help, and any additional advise you may have.
Tim Barbour
Hi Tim,
I don't know any specific answers, but things to experiment with include:
-script instead of _script
ThisDrawing.SetVariable "FileDia", 0
When assembling the string for the path you need to include the inverted
commas as part of the string
Use & to join strings, not +
Use \\ rather than \ as dividers for the directories.
Laurie Comerford
CADApps
www.cadapps.com.au
news:f1967a6.1@WebX.maYIadrTaRb...
> Hi Laurie,
command" script.
in pieces.
> Tim Barbour
Use double quote before and after
folder+filename
Saludos,  Ing. Jorge Jimenez, SICAD S.A., Costa Rica
Hi
Laurie,
command" script.
pieces.
Tim Barbour
Thisdrawing.SendCommand 'script filenameSCR &
vbCrLf
filenameSCR  = chr(34) & path15 &
foldername & chr(92) & fileName & ".scr" & chr(34)
Tim Riley
Hi
Laurie,
command" script.
pieces.
Tim Barbour
Hi laurie
i dono vba .
i want to open autocad from the excell  using vba  and run the scr file i like in autocad how can i accomplish it i need exact code to do so,
my scr file is test.scr and file location :d\   so can anyone plse tell exact code to load this scr file and i need run some other vba code at the end of this code how can i control that tooo some one explain plse .
