routine to extract object that meet certain criteria
i am in need of a routine that will search my selection for circle radius = 21.3 and will put the coordinates of those circles in a text file or an excel file...any ideas?
Well, here's how to get the object data you want: Sub circ_rad() Dim ss As AcadSelectionSet Dim dxfCode(1) As Integer Dim dxfVal(1) As Variant Dim ent As AcadEntity Dim circ As AcadCircle Dim cen Set ss = ThisDrawing.PickfirstSelectionSet dxfCode(0) = 0: dxfVal(0) = "CIRCLE" dxfCode(1) = 40: dxfVal(1) = 21.3 ss.Select acSelectionSetAll, , , dxfCode, dxfVal For Each ent In ss Set circ = ent cen = circ.Center Debug.Print "Center X = " & cen(0); ", Center y = " & cen(1); ", Center Z = " & cen(2) Next End Sub -- Jeff check out www.cadvault.com "jbryant4" wrote in message news:3498544.1109271280093.JavaMail.jive@jiveforum2.autodesk.com... >i am in need of a routine that will search my selection for circle radius = >21.3 and will put the coordinates of those circles in a text file or an >excel file...any ideas?
i copied the routine, opened up the VB editor, pasted the copied text and ran...where does the output go to?
view|immediate (ctl + g) debug.print means print to immediate window "jbryant4" wrote in message news:29628325.1109273916443.JavaMail.jive@jiveforum1.autodesk.com... > i copied the routine, opened up the VB editor, pasted the copied text and ran...where does the output go to?
so when i run the routine, i should see the info in the ACAD text box? I am new to all of this, so your patience is greatly appreciated
No, in the VBAIDE press CTRL G to bring up the immediate window and it will be shown there. This was merely an example to show you how to get the data. To display it in acad, you could add this line below the Debug.Print..... line: circ.Highlight True MsgBox "Center X = " & cen(0) & ", Center y = " & cen(1) & ", Center Z = " & cen(2) circ.Highlight False You will need additional code, most of which can be found in the help files and example code, to export to a text or excel file. -- Jeff check out www.cadvault.com "jbryant4" wrote in message news:8031806.1109276932549.JavaMail.jive@jiveforum2.autodesk.com... > so when i run the routine, i should see the info in the ACAD text box? I > am new to all of this, so your patience is greatly appreciated
