Rotating items in selection set
I have created a selection set of all the items on a particular layer.
Is i t possible to then rotate the selectio set?
any help will be appreciated
thanks
Thomas Tavrides
Machine Designer
Century Design Company
(708) 598-5111 x114
You can't rotate the selection set itself but you can rotate each item
within it:
For i = 0 To ss.Count - 1
ss.Item(i).Rotate basePoint, rotationAngle
Next
Visit me at http://www2.stonemedia.com/franko
"Tom Tavrides" wrote in message
news:ef03a7f.-1@WebX.SaUCah8kaAW...
> thanks
> Thomas Tavrides
> Machine Designer
> (708) 598-5111 x114
Thanks Frank that worked.
I need to continualy rotate these items, perhaps i should make them into a
block.
Can i just add all items in the SS to a block or is it possible to add all
items from a particular layer straight to a block
tom t
You can add any AcadEntity object to a block. Use the CopyObjects method of
the AcadDocument class to do this. If the objects you want to block are in a
selection set, there is an example at my web site showing how to use a
selection set to add items to a block definition. Look at How Do I? ->
Visual Basic -> Use existing objects to create a block definition? As for
adding all items from a given layer, you can use a selection set to grab
everything on a given layer then use the same technique to add the selection
set to your block definition.
news:ef03a7f.1@WebX.SaUCah8kaAW...
> block.
> tom t
Thanks Frank
That worked out great
tom
