right justify a string
Hopefully there is an easy answer to this question but I'm at a lose for the
moment.
Dim X As String * 10
X = "1.000"
I want X to equal " 1.000"
Thanks!
Joe ...
mdhutchinson
... doesn't work to simply embed a space?
X = " 1.0000"
Nope, but I came up with this solution. Watch out for word-wrapping!
Joe ...
Public Function RightJustifyFixedLengthString(FixedLengthString As String)
As String
FixedLengthString = Right(FixedLengthString, Len(FixedLengthString) -
Len(RTrim(FixedLengthString))) & RTrim(FixedLengthString)
End Function
Public Sub Test()
Dim FixedLengthString As String * 10
FixedLengthString = "1.000"
RightJustifyFixedLengthString FixedLengthString
Debug.Print FixedLengthString
End Sub
wrote in message news:5540385@discussion.autodesk.com...
X = " 1.0000"
Ed__Jobe
Hi Joe. Should the function return the value, like this:
[code]
Public Function RightJustifyFixedLengthString(FixedLengthString As String) As String
RightJustifyFixedLengthString = Right(FixedLengthString, Len(FixedLengthString) - _
End Function[/code]
Also, this worked for me. It padded two spaces in front.
[code]
FixedLengthString = " " & FixedLengthString[/code]
You would just have to calculate how many spaces to use. Granted, that might take more code than what you came up with, but it just seemed like you were saying that adding spaces didn't work.
Ed
How to post your code.
Ed,
That's what my code does. It takes the len of the whole string - the length
of the actual string = the amount of space needed. Then concate the actual
string to the pad and that's it.
Joe ...
wrote in message news:5540481@discussion.autodesk.com...
[code]
As String
End Function[/code]
[code]
Ed__Jobe
Yes, I knew that, but I think I misread Hutch's response and therefore what you were saying "Nope" to. Sorry.
Ed
Not a problem, I appreciate the feedback.
Joe ...
wrote in message news:5541209@discussion.autodesk.com...
