Reverse Array (yarra?)
I have a quick question - In a VBA routine - I have an array of an undetermined amount, could be two items or twenty items. what I think I want to do is to reverse the order they are in. i.e. (1, 2, 3, 4) becomes (4, 3, 2, 1). Is there a SIMPLE way to do this?? The size of the array is based on the user pressing the "ADD" command button, which redimensions the array. Any help would be greatly appreciated.
Dave. K
Here's a way I have done it, there may be something
more efficient out there?
Sub Test()
  Dim sArray(5) As
String
  Dim vTemp As Variant
  Dim i As Integer
  sArray(0) = "A"
  sArray(1) = "B"
  sArray(2) =
"C"
  sArray(3) = "D"
  sArray(4) = "E"
  sArray(5) =
"F"
  Do
    vTemp =
sArray(i)
    sArray(i) = sArray(UBound(sArray) -
i)
    sArray(UBound(sArray) - i) =
vTemp
    i = i + 1
  Loop Until i = (UBound(sArray) +
(UBound(sArray) Mod 2)) / 2
  For i = LBound(sArray) To
UBound(sArray)
    Debug.Print sArray(i)
Next
End Sub
  Jacob Dinardi
I
Dave. K
Thanks, I'll give that a try. Looks like it will do the trick, But I sure wish there was something a little simpler. In LISP all I need do is "(reverse LIST)" Oh well I guess if it was easy everybody'd be writing programs!
SEEYA!
Dave. K
It would be nice to have a built in function, but
this is pretty simple, 6 lines of code to actually do the work... you can make
your own function and reuse it.
SEEYA!
Dave. K
Instead of reversing the array, just step thru it
backwards.
for i = ubound(myArray) to lbound(myArray)
-1
    'do your stuff
I
Dave. K
Oops, got a little quick on the draw, that's:
for i = ubound(myArray) to lbound(myArray) Step -1
"Bobby C. Jones" wrote in message
news:9B4D4013B2CB55C9153D43A78C6C6E0D@in.WebX.maYIadrTaRb...
Instead of reversing the array, just step thru it backwards.
for i = ubound(myArray) to lbound(myArray) -1
'do your stuff
next i
Bobby C. Jones
www.AcadX.com
"KingCAD" wrote in message
news:f102de4.-1@WebX.maYIadrTaRb...
Dave. K
