Resume statement
Resume statement
Resume statement
Howdy all,
I have the following code... if the user selects an invalid object, I want a
message box displayed and then allow the user to make a new selection. When
I try to force an error by picking on a non text item, I get my message box
as normal, but I can not dismiss the message box and AutoCAD and VBA hang.
I have gotten it to work by adding the line argument after resume i.e.
Resume 21, but I then get two message boxes from the error before allowing
Dim objText As AcadText
Dim Ent1 As AcadEntity
On Error GoTo Err_Control:
ThisDrawing.Utility.GetEntity Ent1, PtNothing, "Select text object."
Ent1.Highlight True
If TypeOf Ent1 Is AcadText Then
Set objText = Ent1
Else
GoTo Err_Control
Err_Control:
Select Case Err.Number
Case Else
Err.Clear
MsgBox "The object you selected is not a text object. Please make a
new selection.", vbExclamation, "My Error"
Ent1.Highlight False
Resume
End Select
Anyone have any ideas?
TIA.
Rob
Rob,
Try an Exit Sub statement as the line before the error handler. Insures
that program flow does not enter the errorhandler again.
Public Sub pick_acadobject()
Dim myacadobj As AcadObject
On Error GoTo errorhandler
ThisDrawing.Utility.GetEntity myacadobj, pickedpoint, "select an AutoCAD
object..."
'object was picked.. do your thing...
Exit Sub
errorhandler:
MsgBox ("you missed. get some glasses... ")
Err.Clear
Resume
End Sub
Cheers,
Ken Hutson
San Antonio, Texas
"Rob Outman" wrote in message
news:47B69526E413625ABC803DD7EA55E95A@in.WebX.maYIadrTaRb...
> Howdy all,
a
When
box
> Ent1.Highlight True
> Set objText = Ent1
> Else
> GoTo Err_Control
> End If
> Err_Control:
> Case Else
> Err.Clear
a
> Resume
> End Select
> TIA.
> Rob
Hi Ken,
Thanx for the advice... I guess I didn't grab that part of the code when I
was cutting and pasting... I actually do have that in my code. It actually
looks like this at the start of the error handler to avoid entering the
error handler as you mentioned. But unfortunately this does not solve my
Resume problem!
Exit_Here:
Exit Sub
Err_Control:
Thanx,
Rob
"Kenneth Hutson" wrote in message
news:9B585E90BC63A5C77ABF224E9EBCDBF5@in.WebX.maYIadrTaRb...
> Rob,
AutoCAD
> object..."
> Exit Sub
> errorhandler:
> Err.Clear
> Resume
> End Sub
> Cheers,
> Ken Hutson
> San Antonio, Texas
> > Howdy all,
want
> a
> When
> box
hang.
allowing
> > Ent1.Highlight True
> > Set objText = Ent1
> > Else
> > GoTo Err_Control
> > End If
> > Err_Control:
> > Case Else
> > Err.Clear
make
> a
> > Resume
> > End Select
> > TIA.
> > Rob
Heya Rob,
This seems works fairly well. Remember that the user may not have anything
to select. User may be looking at an empty layout or drawing. Give a choice
to bail out or retry in that case.
Public Sub pick_a_text()
Dim myacadobj As AcadEntity
Dim response As Variant
Dim pickpoint As Variant
On Error Resume Next
ThisDrawing.Utility.GetEntity myacadobj, pickpoint, "Select a text..."
Select Case True
Case Err.Number <> 0
Err.Clear
response = MsgBox("you missed everything", vbRetryCancel)
If response = 4 Then
pick_a_text
Else
Exit Sub
Case Else
If TypeOf myacadobj Is AcadText Then
MsgBox ("good choice")
'do stuff here
Else
response = MsgBox("not text..", vbRetryCancel)
pick_a_text
End Select
End Sub
Cheers,
Kenneth Hutson
San Antonio, Texas
news:ABD6C6654C921E79707D19ADA6AC8957@in.WebX.maYIadrTaRb...
> Hi Ken,
actually
> Resume problem!
> Exit_Here:
> Exit Sub
> Err_Control:
> Thanx,
> Rob
> > Rob,
> AutoCAD
> > object..."
> > Exit Sub
> > errorhandler:
> > Err.Clear
> > Resume
> > End Sub
> > Cheers,
> > Ken Hutson
> > San Antonio, Texas
> > > Howdy all,
> want
> > a
> > When
message
> > box
> hang.
> allowing
object."
> > > Ent1.Highlight True
> > > Set objText = Ent1
> > > Else
> > > GoTo Err_Control
> > > End If
> > > Err_Control:
> > > Case Else
> > > Err.Clear
> make
> > a
> > > Resume
> > > End Select
> > > TIA.
> > > Rob
Thanx Ken,
That worx great!
Rob
news:621E7AC4D7656711574352DFA1FB6894@in.WebX.maYIadrTaRb...
> Heya Rob,
anything
choice
> Select Case True
> Err.Clear
> pick_a_text
> Else
> Exit Sub
> End If
> Case Else
> 'do stuff here
> Else
> pick_a_text
> End If
> End If
> End Select
> End Sub
> Cheers,
> Kenneth Hutson
> San Antonio, Texas
> > Hi Ken,
I
> actually
my
> > Resume problem!
> > Exit_Here:
> > Exit Sub
> > Err_Control:
> > Thanx,
> > Rob
> > > Rob,
Insures
> > AutoCAD
> > > object..."
> > > Exit Sub
> > > errorhandler:
> > > Err.Clear
> > > Resume
> > > End Sub
> > > Cheers,
> > > Ken Hutson
> > > San Antonio, Texas
> > > > Howdy all,
I
> > want
> > > a
selection.
> > > When
> message
> > > box
> > hang.
i.e.
> > allowing
> object."
> > > > Ent1.Highlight True
> > > > Set objText = Ent1
> > > > Else
> > > > GoTo Err_Control
> > > > End If
> > > > Err_Control:
> > > > Case Else
> > > > Err.Clear
> > make
> > > a
> > > > Resume
> > > > End Select
> > > > TIA.
> > > > Rob
