REPLACE
REPLACE
Message 1 of 16
REPLACE
I am trying to make an autocad routine that allows the user to select a text or mtext object one at a time using the mouse and look for "S" within that text and replace it with "N" Note: The "S" will only appear once within the object. Any ideas?
Replies (15)
Message 2 of 16
VBA has a Replace function for strings.
Message 3 of 16
Try the following
Sub ReplaceSwithN()
On Error Resume Next
Dim oEnt As AcadEntity
Dim Pt
Dim sTmp As String
ThisDrawing.Utility.GetEntity oEnt, Pt
Do While Err = 0
ReplaceString oEnt, "S", "N"
Loop
Err.Clear
End Sub ' ReplaceSwithN
Function ReplaceString(oEnt As AcadEntity, sCurrent As String, sNew As
String) As Boolean
Dim oText As AcadText
Dim oMText As AcadMText
ReplaceString = True
If TypeOf oEnt Is AcadText Then
Set oText = oEnt
sTmp = oText.TextString
sTmp = Replace(sTmp, sCurrent, sNew)
oText.TextString = sTmp
oText.Update
ElseIf TypeOf oEnt Is AcadMText Then
Set oMText = oEnt
sTmp = oMText.TextString
oMText.TextString = sTmp
oMText.Update
Else
MsgBox "The selected object was neither Text or MText", vbInformation
ReplaceString = False
End Function ' ReplaceString
Regards
Laurie Comerford
wrote in message
news:5864036@discussion.autodesk.com...
object. Any ideas?
Message 4 of 16
As was mentioned in other posts, you can use the VBA Replace() function to replace parts of a string.
But, you should not consider the code Laurie posted a good example of how to do that, because it calls Replace() on every selected text/mtext object and reassigns the result, even when it's unnecessary (e.g., when the string to replace does not even exist in the text).
Instead, use the InStr() function to see if the string you want to replace exists in the text string first, and only proceed to use Replace() if it does.
That also allows you to report back to the user, how many text objects were actually modified.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5864036@discussion.autodesk.com...
Message 5 of 16
Laurie,
Thanks for the quick reply. I inserted the code as shown but it doesn't seem to replace anything?
Message 6 of 16
Hi Tony,
Did you notice that the request from the user was for code when the text is
hand selected?
Did you see any requirement to count the results?
Obviously, if the whole process was to be fully automated, you would not use
the "replace" command. As as you pointed out a few months ago, it is
quicker to use a combination of instr and re-assembly of the string. But
the speed issue harfly arises in this case and I opted for simplicity of the
code..
Regards
Laurie Comerford
"Tony Tanzillo" wrote in message
news:5864284@discussion.autodesk.com...
does.
actually modified.
wrote in message
object. Any ideas?
Message 7 of 16
Why not step through the code and see where it it not doing as you expect?
It certainly worked for me before I posted it.
Regards
Laurie Comerford
wrote in message
news:5864355@discussion.autodesk.com...
Laurie,
Message 8 of 16
Thanks Laurie. Can you do the same thing but like this?
Change all "N" to "S"
all "S" to "N"
all "E" to "W"
and all "W" to "E"
I thought I could figure it out with a little help of example usage but it is harder than I thought.
Message 9 of 16
Cycle through each character using the Mid function rebuilding the string with the changes as necessary.
Message 10 of 16
I AM NEW TO VB. CAN YOU PROVIDE EXAMPLE. LAURIES CODE WITH MY MESSED UP ATTEMPT IS AS FOLLOWS...
Do While Err = 0
Dim oEnt As Object 'AcadEntity
Dim Pt
Dim sTmp As String
Thisdrawing.Utility.GetEntity oEnt, Pt
'Do While Err = 0
DoEvents
ReplaceString oEnt, "E", "W"
DoEvents
DoEvents
ReplaceString oEnt, "W", "E"
ReplaceString oEnt, "N", "S"
DoEvents
Loop
Err.Clear
Message 11 of 16
The problem is you have already replaced one string with another and then change it back.
Look in the help files for info on sting handling functions such as Mid & Len.
Message 12 of 16
Think about what you're asking it to do...
wrote in message
news:5864868@discussion.autodesk.com...
ok so now all N are S
all "S" to "N"
now you change all S back to N
same with e and w
all "E" to "W"
and all "W" to "E"
so if you want to do that kind of thing you'll need interim place holders
Change all "N" to "wasN" 'or other temp placeholder certain to *not exist
currently*
Change all "S" to "N"
Change all "wasN" to "S"
or something like that...
hth
mark
Message 13 of 16
If you look at the line:
You can change that line to be:
or
In each case the first string is replaced by the second one
So now all you need is a means of distinguishing which repalcement you wish
to make which can be done like this:
Set oText = oEnt
WhichReplacement oEnt, sTmp
Set oMText = oEnt
Else
Function WhichReplacement (oEnt as AcadEntity, sTmp as String)
If Instr(sTmp, "N" > 0 Then
ElseIf Instr(sTmp, "S" > 0 Then
ElseIf Instr(sTmp, "W" > 0 Then
ElseIf Instr(sTmp, "E" > 0 Then
End Function
I'm unsure if you expect combinations of N and W or N and E etc. If you do
then the code statements need to be changed to:
End Function
Also, you may care to remove the messagebox from the ReplaceString Function,
as with these changes, you don't need it there
I haven't tested this, and may have missed a couple of Dim statements, but
you can add those as needed
Regards
Laurie Comerford
wrote in message
all "S" to "N"
all "E" to "W"
and all "W" to "E"
Message 14 of 16
I love this discussion group. It works great! But, It works great in AutoCad 2002 but it doesn't work at all in AutoCad 2007?????????????????????
Message 15 of 16
The above listed code that is.
Message 16 of 16
Why doesn't it work in Acad 2007?
