Renaming *-E Layer Names to Exst
Message 1 of 11
I am trying to rename a group of layers that end with -E to Exst But thing
is I want to get rid of the -E and everytime I run my macro it just adds
Exst to the end of my layer names... does any one know how to subtrat the
last 2 characters and swap the name to Exst?
Public Sub RenameLayers()
Dim lays As AcadLayers
Dim layerObj As AcadLayer
Dim lay As AcadLayer
Dim strLayerName As String
On Error Resume Next
Set lays = ThisDrawing.Layers
For Each lay In lays
Set layerObj = ThisDrawing.Layers(lay.Name)
strLayerName = layerObj.Name
layerObj.Name = strLayerName & "Exst"
Next lay
End Sub
Replies (10)
Message 2 of 11
There could be various ways of doing what you want, but I would do like this:
For Each lay In ThisDrawing.Layers
lay.Name = Replace(lay.Name, "-E", "-Exst")
Next lay
Message 3 of 11
"Rick Holguin" wrote in message
news:5866280@discussion.autodesk.com...
layerObj.Name = Replace( strLayerName , "-E", "Exst")
Next lay
End Sub
hth
mark
Message 4 of 11
Ok let me try it.. thanks for your help!
wrote in message news:5866291@discussion.autodesk.com...
this:
Next lay
Message 5 of 11
It works perfect..... but If I want to have a dialog box pop up and have an
input box then all I have to do is create a string for the layer prefix "-E"
right?
this:
Next lay
Message 6 of 11
I am not a big fan of dialog boxes for user inputs, unless really necessary. I prefer using the command prompt. Here is how I would do it.
Public Sub LayerName_Change()
Dim str As String
str = ThisDrawing.Utility.GetString(False, "Enter layer name prefix: ")
lay.Name = Replace(lay.Name, "-E", IIf(Len(str) = 0, "-Exst", str))
Next lay
End Sub
Message 7 of 11
How about this 2 command promts....
Check it out!!! thanks John!! john you know your stuff... send me your
direct email adress.... if not its ok thanks for your expertise!! you da
man!
Dim str As String
Dim str2 As String
str2 = ThisDrawing.Utility.GetString(False, "Enter prefix layer name To Be
Changed: <-E> ")
lay.Name = Replace(lay.Name, str2, IIf(Len(str) = 0, "-Exst", str))
Next lay
End Sub
wrote in message news:5867190@discussion.autodesk.com...
Dim str As String
Next lay
End Sub
Message 8 of 11
fwiw, from your posts looks like you're actually doing suffixes not prefixes
mark
news:5867442@discussion.autodesk.com...
man!
Dim str As String
Dim str2 As String
Changed: <-E> ")
Next lay
End Sub
Dim str As String
Next lay
End Sub
Message 9 of 11
Yes its suffix... hey do I get it to do Prefix.... you know in the middle of
a layer name??
"MP" wrote in message
news:5867515@discussion.autodesk.com...
mark
man!
Dim str As String
Dim str2 As String
Changed: <-E> ")
Next lay
End Sub
Dim str As String
Next lay
End Sub
Message 10 of 11
Look at Instr and Mid$
news:5867609@discussion.autodesk.com...
a layer name??
mark
man!
Dim str As String
Dim str2 As String
Changed: <-E> ")
Next lay
End Sub
Dim str As String
Next lay
End Sub
Message 11 of 11
Thanks for your help!
news:5867822@discussion.autodesk.com...
a layer name??
mark
man!
Dim str As String
Dim str2 As String
Changed: <-E> ")
Next lay
End Sub
Dim str As String
Next lay
End Sub
