Reload Xref's
Reload Xref's
Message 1 of 8
Reload Xref's
Is it possible to reload xref's using vb?
How?
Replies (7)
Message 2 of 8
Yes - For each XREF in your drawing there is an AcadBlock
object in the Blocks collection. The AcadBlock object has
methods Unload() and Reload() that will unload and reload
an external reference.
"Mark Palacios" wrote in message
news:f09ff39.-1@WebX.maYIadrTaRb...
> Hello,
> How?
Message 3 of 8
Thank you very much,
I did as you suggested and created the following
code:
  Private objADT As
AcadApplication
  Private objDoc As AcadDocument
  Private
objBlock As Object
  Private objBlocks As AcadBlocks
  Set objDoc =
objADT.ActiveDocument
  Set objBlocks = objDoc.Blocks
  For Each objBlock In
objBlocks
    If objBlock.IsXRef = True
Then
      objBlock.Reload
    End
If
  Next
Upon completion, it crashes with a Automation
Error.  If I insert
  On Error Resume
Next
prior to the For..Each loop it works ok.
However sometimes it does not work.  It seems to skip Xref's that are
inserted in paperspace the first time, but then later it will work on them
also.  I am so comfused.  Any suggestions?
> Yes - For each
"Mark Palacios" <
size=2>mark@palacios
> wrote in
message
face=Arial size=2>news:f09ff39.-1@WebX.maYIadrTaRb
size=2>...
> > Hello,
> > Is it possible to
> > How?
Message 4 of 8
news:CE3953803D1A2CFCAFDBB327377E3A39@in.WebX.maYIadrTaRb...
> Upon completion, it crashes with a Automation Error.
What is the error?
Message 5 of 8
It says:
Run-Time Error -2147467259 (80004005)
Automation Error
"Tony Tanzillo" wrote in message
news:BE2AFF60175CCCFBE5E45FDD855CDD13@in.WebX.maYIadrTaRb...
> What is the error?
Message 6 of 8
I'm not really sure what is causing that, but I would
not be able to tell you much without seeing the code.
news:62FF2CEC68583E43C52994307AD0D714@in.WebX.maYIadrTaRb...
> It says:
> Automation Error
> > What is the error?
Message 7 of 8
Using the following code in VBA
Dim objBlock As AcadBlock
Dim objBlocks As AcadBlocks
Set objBlocks = Application.ActiveDocument.Blocks
For Each objBlock In objBlocks
If objBlock.IsXRef = True Then
objBlock.Reload
Next
causes the same automation error after it iterates through the the blocks
collection.
news:829EBF9ACCE2779B47C7A16711E5FC2B@in.WebX.maYIadrTaRb...
> > It says:
> > Automation Error
> > > What is the error?
Message 8 of 8
You say this happens after iterating through the
blocks collection. Does the code completely process
all blocks before the error occurs?
news:7A80F0AB61908A635F6B23BA6B58212B@in.WebX.maYIadrTaRb...
> objBlock.Reload
> End If
> Next
> collection.
