Reg. Cannot Create ActiveX Component
Message 1 of 1
While the AutoCAD application is opened by manually and after that if I run the mentioned code then it is fine.
But while crating object (Opening AutoCAD using Code) I am getting the error message thet " Cannot create ActiveX component "
Dim objAcadApp As AcadApplication
        Try
            objAcadApp = GetObject(, "AutoCAD.Application.19")
            If objAcadApp Is Nothing Then
                objAcadApp = CreateObject("AutoCAD.Application.19")
      Catch ex As Exception
            MessageBox.Show(ex.Message)
        End Try
Replies (0)
