Redefining the Block - Pls help
Hi There,
Is anyone know how to redefine the block ? Please help...
Following is my requirement :
A1-D > is existing block (internal block -not xref)
A1-D Case.dwg > external block stored in the folder, I want to replace A1-D with this one inside autocad.
I have blockname in variable but did not find any function to redefine it, please help...
Thanks very Much
Bassya
SEANT61
This posting has an example of just such a process.
http://www.cadtutor.net/forum/showpost.php?p=152020&postcount=13
May your cursor always snap to the location intended.
Thanks for reply,
But the code is not working, I'm using autocad 2009 and changed your code for strBlockName to "A1-D"
and strPath "D:\temp\" it says, End of statement, syntax error at AxDbDocument.
Any trick ? As I said before I want to redefine block with "a1-d" to "a1-d case" out of few blocks in the drawing.
Any straight forward code will be really appreciated.
Bassya
SEANT61
You may not have noticed this note in the linked post:
Make note of the line:
Set ACDbx = ThisDrawing.Application.GetInterfaceObject("Object DBX.AxDbDocument.16") 'set to appropriate version
in the attached code.
In your case it would be:
Set ACDbx = ThisDrawing.Application.GetInterfaceObject("ObjectDBX.AxDbDocument.17") Edited by: SEANT61 on Feb 16, 2009 3:07 AM
SEANT61
Actually, something I just noticed; you are not actually redefining the geometry of an existing block, you are substituting blocks (i.e., block with block of a different name).
That is a more straightforward process. I don’t have ready made code but, essentially, you just need to:
Iterate all the inserts with .Name “A1-D”, make note of .InsertionPoint, .Rotation, etc.
Delete “A1-D”
Insert “D:\temp\A1-D case” with all of the gathered properties.
