Redefining blocks
Redefining blocks
Redefining blocks
Hello all.
I've looked through the N/G and found some posts regarding redefining
objects colors within a block, but what I'm looking to do is completely
redefine the block with another block.
Any info would be greatly appreciated.
Thank you
Warren Medernach
This probably isn't the best way but...
If the new block definition is an external dwg file, you could possibly use
SendCommand to mimic the way a user would redefine a block.
To redefine a block in AutoCAD you use the command line "-Insert" command
and at the prompt for the block name you enter the "existing block name =
external dwg name". This is how the user would do it in AutoCAD;
Command: -insert
Enter block name or [?] <>: "Hydrant=D:\Symbols\Hydrant2"
Block "Hydrant" already exists. Redefine it? [Yes/No] : y
Block "Hydrant" redefined
Regenerating model.
Specify insertion point or [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:
The name of the external file can be the same as the block or different.
Glen
Warren Medernach wrote in message <7ufusf$oae16@adesknews2.autodesk.com>...
>Hello all.
>Thank you
>Warren Medernach
