Read Object Data, Map3D 2009
I have created a selection set of entities that I would like to annotate and move to certain layers based on their object data. I'm hung up on reading each entities object data. I have been able to find examples of how to change object data, but nothing on reading that object data into variables. My basic workflow is as follows:
1) Using MapImport, import a shapefile and read it's object data into an Object Data Table
2) Select the imported data, and based on the entities object data, place each polygon on it's appropriate layer and annotate from it's object data.
Suggestions?
First, make sure you have the  appropriate
object reference loaded. My 2008 install had 'Autodesk Map 3d 2005' loaded along
with AutoCAD 2008 Type library
then:
 Dim Amap As AcadMap
 Dim ODrcs As
ODRecords
 Dim SSet As AcadSelectionSet
 Dim ent
As Object
 Dim BoolVal As Boolean
 Dim RetStr as String
  Set Amap =
ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
Set ODrcs = Amap.Projects(ThisDrawing).ODTables.GetODRecords
  <initialize selection set & get
your data into the selection set by your favoriate means>
For each ent in SSet
    BoolVal = ODrcs.Init(ent, False,
False)
    RetStr =
VBA.Trim(ODrcs.Record.Item(0).Value)
    'When selecting values from the
ODrcs.record, remember that the table is an array starting at 0 for the first
element...
    <...Do what you need to with returned values
here...>
Next
'clean up after yourself
SSet.Clear
SSet.Delete
End Sub
Obviously I'm not including a lot of error checking
and such in this code. It's pulled from stuff I wrote 5+ years ago and haven't
revisited because nothing broke.
Hope this helps
Tom
I
workflow is as follows: 1) Using MapImport, import a shapefile and read it's
object data into an Object Data Table 2) Select the imported data, and based
annotate from it's object data. Suggestions? Thanks
Thanks Tom
For my next question:
I am getting run time error '-2145386418 (8020004e)': object was open for read
I am guessing that the script line BoolVal = ODRec.Init(ModObj, False, False) opens the record for reading. How do I close that record so that I can modify the object in ModObj (change it's layer and annotate it)
My code as of now:
Dim ModObj As Object
Dim DispNum As String, DispType As String, DispOwn As String, DispSurv As String, LTOPlan As String
Dim Amap As AcadMap
Dim ODRec As ODRecords
Set Amap = ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
Set ODRec = Amap.Projects(ThisDrawing).ODTables.GetODRecords
For Each ModObj In objSS
DispNum = VBA.Trim(ODRec.Record.Item(1).Value)
DispType = VBA.Trim(ODRec.Record.Item(2).Value)
DispOwn = VBA.Trim(ODRec.Record.Item(3).Value)
DispSurv = VBA.Trim(ODRec.Record.Item(5).Value)
LTOPlan = VBA.Trim(ODRec.Record.Item(6).Value)
Debug.Print DispNum, DispType, DispOwn, DispSurv, LTOPlan
If DispType = "MSL" Then
'ModObj.Layer = "lse-bdy"
Next
Kris Edited by: kristopherschmidt on Jun 23, 2009 11:34 AM
As a follow-up, I have been able to figure this one out. Code as follows:
Dim Amap As AcadMap
Dim DispLbl As AcadMText
Dim TxtPoint As Variant
Dim TxtFormat As String
TxtFormat = "\Farrusn.shx;\H2.0;"
'Debug.Print DispNum, DispType, DispOwn, DispSurv, LTOPlan
Set ODRec = Nothing
ModObj.Layer = "LSE-BDY"
If DispType = "LOC" Then
ModObj.Layer = "LSE-LOC"
If DispType = "PLA" And LTOPlan <> "" Then
ModObj.Layer = "ROW-REG"
If DispType = "PLA" And LTOPlan = "" Then
ModObj.Layer = "ROW-UNR"
Next Edited by: kristopherschmidt on Jun 24, 2009 4:25 PM
