Quote in a string
Quote in a string
Quote in a string
Is there a way to express the string 3" in vba other than "3" & chr(34)?
"3"" obviously doesn't work. It is for a text box validation that passes the
contents to an SQL query. When the user enters a double quote I want to
translate it into something SQL likes.
Dale
Sample:
ls_Desc = "*" & as_D & "*"
SQL String portion = tblCustomPricingQuotes.Description LIKE " & Chr(34) &
ls_Desc & Chr(34)
Now as_D is the string that gets passed from the text box whixh will allow
the recordset to include all records where field "Description" contains the
text passed via as_D.
If user enters X then the matxh string is "*X*". As soon as the user enters
a double quote I get an SQL query error when it tries to pass the query
string.
Any suggestions?
Dale
If _D held consistent data, you could just build your sql string
appropriately. But since its variable, you'll have to test whether or not it
contains a double quote before you build your sql string. Search _D for a
double qoute and replace it with two double qoutes.
Ed
"Dale Levesque" wrote in message
news:F045C74420F8D15F10553B59033EE94C@in.WebX.maYIadrTaRb...
> Sample:
> ls_Desc & Chr(34)
the
enters
> string.
> Any suggestions?
> Dale
Works great!
"Ed Jobe" wrote in message
news:97B0EF0F405958AD8149907FB958B9DA@in.WebX.maYIadrTaRb...
it
> Ed
> > Sample:
Chr(34)
> > ls_Desc & Chr(34)
allow
> the
> enters
> > string.
> > Any suggestions?
> > Dale
"3"" won't work, of course. the first " and the last " are bracket for a
string value. To present a " value in VB's string, you duoble the ", that
is:
Dim myString As String
myString="3""" 'the string's value is 3"
myString="ABCD""EFG" 'the string's value is ABCD"EFG
news:4F74F895861B84222E5DB47BB8F8C9E6@in.WebX.maYIadrTaRb...
the
> Dale
Not sure what method you used to implement Ed's suggestion, but if you're using VBA 6.x there is a Replace function that'll do the work for you.
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
Thanks, I have one.
Not
Regards
Wayne Ivory
IT Analyst
Programmer
