PUBLISH command causes fatal error
Hi
I've made an VBA macro that makes a *.DSD file. Then I use the -PUBLISH
command with the dsd-file as an argument to create a multipage DWF.
However...
If a VBA macro is run directly before the publish command is issued, a Fatal
Error occurs.
i.e. if i place THIS on a button:
^C^C-vbarun;Jadda;(setq oldDia (getvar "FILEDIA"))(setvar "FILEDIA"
0)(command "_-PUBLISH" "C:/Documents and Settings/6TROLIE/Local
Settings/Temp/MPDWF.DSD")(setvar "FILEDIA" oldDia);
AutoCAD crashes when I press it.
iI i put
^C^C-vbarun;Jadda;
and
(setq oldDia (getvar "FILEDIA"))(setvar "FILEDIA" 0)(command "_-PUBLISH"
"C:/Documents and Settings/6TROLIE/Local Settings/Temp/MPDWF.DSD")(setvar
"FILEDIA" oldDia);
on two separate buttons, and press them in order, everything works fine.
The DVB file only consist of 1 module with this:
Public Sub Jadda()
End Sub
I've tried this on both AutoCAD 2004, Architectural Desktop 2004 and
Mechanical 2004.
Does anyone know anything about this?
Regards
Trond Hasse Lie
Well, first off why are you setting variables thru lisp in a button?
Buttons are for macros - why make things hard? Just use ^C^C-
vbarun;jadda;setvar;useri1;(getvar"filedia");filedia;0;-
publish;"....dsd";filedia;(getvar"useri1");
Second, why not include all of this in your vba program to begin with?
Third, what does jadda do? It could be causing an problem with the
publish command.
___________________________
Mike Tuersley
AutoCAD Clinic
Rand IMAGINiT Technologies
Well I could of course use standard commands for the FILEDIA oart, but you
HAVE to use lisp for the PUBLISH command. Try using a \ (Backslash) in the
command and you'll know what i mean.
Second.. I've tried using Sendcommand etc. for the Publish-part, but it
fatal errors then too. The Publish command doesn't have an API so I have to
use sendcommand. And the REASON I use the Publish command is that it is the
only way to make a MulitPage DWF via VBA.
Third.. As I wrote.. "Jadda" does NOTHING. the code is:
Public Sub Jadda()
End Sub
The problem is: IF I run a VBA macro (even if the macro doesn't do anything)
right before executing the publishcommand, Autocad crashes. If I run the VBA
macro on one button, and run the publishcommand on another button,
everything is just fine.
Trond Hasse Lie
"Mike Tuersley" wrote in message
news:MPG.19dd27363c43e26498977a@discussion.autodesk.com...
> publish command.
> Mike Tuersley
> AutoCAD Clinic
