Problem with vl-vbaload...
I have successfully implimented (vl-vbaload "myproj") into my s::startup in a particular .mnl file.....at least on my workstation.
An error is returned on all other workstations that says "problem loading" the vba project. I tried adding (vl-load-com) just before the vl-vbaload command, but it didn't make a difference.....
I'm missing something.....someone toss me a bone, please!!
TIA,
Rich
If you just have the file name "myproj" and not the full path, the acad probably can't find it. Add the file's folder to the support path. -- ---- Ed ---- "SteelDetailer" wrote in message news:15414908.1080168596470.JavaMail.jive@jiveforum1.autodesk.com... > I have successfully implimented (vl-vbaload "myproj") into my s::startup in a particular .mnl file.....at least on my workstation. > > An error is returned on all other workstations that says "problem loading" the vba project. I tried adding (vl-load-com) just before the vl-vbaload command, but it didn't make a difference..... > > I'm missing something.....someone toss me a bone, please!! > > TIA, > Rich
"myproj" is already in one of the support paths.
Are the support paths set before or after s::startup?
Message was edited by: SteelDetailer
