problem with block
problem with block
problem with block
I made some dynamic blocks, they have 2 parameters. to strech my block. It works perfectly when i test then.
So i insert them in vba, but when i test my block i get the next result ( look at the picture i added).
What can i do about this ?
thanks
dbroad
Be specific about the error.  It appears that you might have included the path in the insert statement.  This would cause the extra redefinition warnings after the first insertion.  The insertion point seems bollixed up as well, but I doubt that is a vba problem.  It might help to see the code fragment.
Architect, Registered NC, VA, SC, & GA.
