problem set active viewport when splited
I want zoom splited viewports in model space with different's directions (top, front...), center and magnitudes. But, when I change the current viewport, all the others lost the zoom I had set.
For Each vport In ThisDrawing.Viewports
ThisDrawing.ActiveViewport = vport 'here the others lost the zoom I had set
When I alter the current viewport manually, clicking in the viewports, it's not occurs.
I see others topics describing the same problem, but no reply, then I'm trying to change the current viewport by 'sendcommand'. Any help to do this?
thanks
would you post the routine please.
Sub VportsUpdate()
Dim vport As AcadViewport
Dim dirTop(0 To 2) As Double
Dim dirFront(0 To 2) As Double
'draw a circle in origin
ThisDrawing.ModelSpace.AddCircle dirTop, 10
'if not splited, split the viewport
If ThisDrawing.Viewports.Count = 1 Then
ThisDrawing.ActiveViewport.Split acViewport2Horizontal
ThisDrawing.Regen acAllViewports
VportsUpdate
'here is the code
If vport.UpperRightCorner(1) = 0 Then vport.Direction = dirTop
If vport.UpperRightCorner(1) = 0.5 Then vport.Direction = dirFront
ThisDrawing.Application.ZoomExtents
Next vport
End Sub
If you stop the execution in the 'Next vport' line, you can see the good result in the Acad window... but after the next 'thisdrawing.activeviewport = vport', the zoomextend is missed.
sorry, in the code paste I forgot initialize the dirTop and dirFront after draw the circle.
dirTop(0) = 0: dirTop(1) = 0: dirTop(2) = 1
dirFront(0) = 0: dirFront(1) = -1: dirFront(2) = 0
Do you have a solution on this problem?
Thank you,
Cata
