Preventing ObjectModified event from firing when saving/regening
I implemented some event handlers to manipulate some objects when some specific MTexts are manually modified with the "MTEDIT" command. Everything works fine except that the "QSAVE" and "REGEN" commands take a bit longer to execute than with the events disabled (about 1-2 seconds more in a drawing with not that many objects). This must be happening because the ObjectModified event is firing countless times when saving. I even put an if statement for the "QSAVE" command inside the event, but it still slows down the saving.
Here is what I first tried:
Public mtextObjHandle As String, currentCommand As String
Sub AcadDocument_BeginCommand(ByVal CommandName As String)
currentCommand = CommandName
End Sub
Sub AcadDocument_ObjectModified(ByVal Object As Object)
If currentCommand <> "QSAVE" And currentCommand <> "VBAIDE" And currentCommand <> "REGEN" Then
If Object.ObjectName = "AcDbMText" Then
mtextObjHandle = Object.handle
End Sub
Sub AcadDocument_EndCommand(ByVal CommandName As String)
If CommandName = "MTEDIT" Then
Dim mtextObj As AcadMText
Set mtextObj = ThisDrawing.HandleToObject(mtextObjHandle)
'here goes the rest of the code
End Sub
I searched some solutions but didn't manage to prevent the event from firing. This next solution resembles something that might work for the "QSAVE" command (probably not for the "REGEN" command), but the event is still firing when saving.
Public WithEvents myDOC As AcadDocument
Public Sub EventON()
Set myDOC = ThisDrawing
End Sub
Public Sub EventOFF()
Set myDOC = Nothing
End Sub
Sub AcadDocument_BeginSave(ByVal FileName As String)
EventOFF
End Sub
Sub AcadDocument_EndSave(ByVal FileName As String)
EventON
End Sub
Sub myDOC_BeginSave(ByVal FileName As String)
EventOFF
End Sub
Sub myDOC_EndSave(ByVal FileName As String)
EventON
End Sub
Sub myDOC_ObjectModified(ByVal Object As Object)
End Sub
Sub myDOC_EndCommand(ByVal CommandName As String)
End SubI am probably doing something wrong, but I never worked with events before so I don't know what might be.
Thank you in advance.
