Possible to insert block from external DWG w/o inserting whole DWG?
junagore
junagore
Hi i need de code to insert a block that is defined inside other DWG file without open this file.
Option Explicit
Private Sub CommandButton5_Click()
Dim VntList As Variant
Dim sBlock As String
Dim sFile As String
Dim i As Integer
Dim pt(2) As Double
pt(0) = 0
pt(1) = 0
pt(2) = 0
sFile = "C:\Program Files\AutoCAD 2005\test.dwg" 'Drawing File
sBlock = "nut" 'Block Name located in Drawing File
VntList = GetBlockListFrom(sFile)
If UBound(VntList) >= 1 Then
For i = 1 To UBound(VntList)
If VntList(i) = sBlock Then
Call CopyBlockFrom(sFile, CStr(VntList(1)))
Call ThisDrawing.ModelSpace.InsertBlock(pt, sBlock, 1, 1, 1, 0)
Exit For
Next i
End Sub
Private Function GetBlockListFrom(sDwgFile As String) As Variant
Dim dbxDoc As Object
Dim sBlock() As Variant
On Error GoTo myfix
Set dbxDoc = AcadApplication.GetInterfaceObject("ObjectDBX.AxDbDocument.16")
dbxDoc.Open sDwgFile
Dim Block As AcadBlock
ReDim sBlock(0)
sBlock(0) = "BlockList"
For Each Block In dbxDoc.Blocks
If Mid(Block.Name, 1, 1) <> "*" Then
ReDim Preserve sBlock(UBound(sBlock) + 1)
sBlock(UBound(sBlock)) = Block.Name
Next Block
GetBlockListFrom = sBlock
Set dbxDoc = Nothing
myfix:
Err = 0
End Function
Private Function CopyBlockFrom(sDwgFile As String, sBlock As String) As Boolean
Dim objs As AcadBlock
Dim objb(0) As Object
On Error GoTo myfix
If Block.Name = sBlock Then
Set objs = Block
Exit For
Next Block
Set objb(0) = objs
dbxDoc.CopyObjects objb, ThisDrawing.Database.Blocks
CopyBlockFrom = True
Exit Function
myfix:
Err = 0
CopyBlockFrom = False
End Function
I hade a error it try this
Option Explicit
Dim sFile As String
Dim i As Integer
Dim pt(2) As Double
pt(0) = 0
pt(1) = 0
pt(2) = 0
Call CopyBlockFrom(sFile, CStr(VntList(i)))
Exit For
Next i
End Sub
On Error GoTo myfix
ReDim sBlock(0)
Next Block
myfix:
Err = 0
End Function
On Error GoTo myfix
Set objs = Block
Exit For
Next Block
Set objb(0) = objs
Exit Function
myfix:
Err = 0
End Function
junagore
thanks, i´ll try it
junagore
Hi wowens9 , lots of thanks i´ll be very helpfull to me.
