Points and properties of objects
Message 1 of 16
Howdy Ya'll (sorry couldn't resist!)
I am trying to get a point (Pt1) on a line by allowing the user to select
the point (first line of code). I have set "OSMODE" to nearest as the exact
point does not matter as long as it falls on the line. I also need to get
the properties of the line with the point on it (Ln2), so I have the user
select that same line again (second line of code). I would rather not have
to use two user picks to achieve this. I have tried to use one line of code
(third line of code below) but sometimes the point does not fall on the line
and this will just not do. Is there a way to only have one user pick to get
the point (Pt1) on the line and get the properties of the line (Ln2)?
Pt1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "Select the opening start
point: ")
ThisDrawing.Utility.GetEntity Ln2, ptNothing, "Select the same wall: "
ThisDrawing.Utility.GetEntity Ln2, Pt1, "Select the opening start point: "
Thanx,
Rob
Replies (15)
Message 2 of 16
If OSMode is bit-coded to "Nea" why don't you just use ptNothing?
http://www.acadx.com
"Rob Outman" wrote in message
news:BD7DC9FBBAC6D7516CF310AE3BA88781@in.WebX.maYIadrTaRb...
exact
code
line
get
| point: ")
| Thanx,
| Rob
Message 3 of 16
It appears to me that the osnaps do not work while using the GetEntity
method... at least I don't get any! I only get the osnaps when I use the
GetPoint method.
Rob
"R. Robert Bell" wrote in message
news:ED38A93BAB30C66E08C4D4D564545FBF@in.WebX.maYIadrTaRb...
select
> exact
get
user
have
> code
> line
> get
> | point: ")
> | Thanx,
> | Rob
Message 4 of 16
Ok, this thing does 2 things i don't like to do... use the user variables
within autocad (because i don't know if others are using them to save
settings for their own programs) and the "SendCommand" (with lisp within
it -- yeeeeach) -- but hey, it gets the job done. The
"GetWallAndNearestPoint" function requires you to feed by reference a
variable for your wall line, and a variable for your "nearest point" and
when its done, those to variables should have the info you need.
Public Function Distance _
(ByVal Point1 As Variant, _
ByVal Point2 As Variant) _
As Double
Dim XDir As Double
Dim YDir As Double
XDir = Abs(Point1(0) - Point2(0))
YDir = Abs(Point1(1) - Point2(1))
Distance = Abs(Sqr((XDir * XDir) + (YDir * YDir)))
End Function
'This will return an endpoint of a line entity, or nothing on error
Public Function GetWallAndNearestPoint(objWall As AcadLine, NearestPoint As
Variant) As Variant
Dim obj As Object
Dim pt As Variant
'Get the object and the point the user picked
ThisDrawing.Utility.GetEntity obj, pt, _
vbCrLf & "Select wall near an end..."
'If its a line, compare where the user picked the line _
to the endpoints and return the closer of the two
If TypeOf obj Is AcadLine Then
Set objWall = obj
'This just turns the variable into a "point array"
NearestPoint = pt
'Get the point...
With ThisDrawing
.SetVariable "lastpoint", pt
.SendCommand ("(setq TempPoint (osnap (getvar ""lastpoint"")
""_nea""))" & vbCr)
.SendCommand ("(setvar ""userr4"" (car TempPoint))" & vbCr)
NearestPoint(0) = .GetVariable("userr4")
.SendCommand ("(setvar ""userr4"" (cadr TempPoint))" & vbCr)
NearestPoint(1) = .GetVariable("userr4")
.SendCommand ("(setvar ""userr4"" (caddr TempPoint))" & vbCr)
NearestPoint(2) = .GetVariable("userr4")
End With
End Function
Message 5 of 16
Use the GetClosestPointTo method of Curve.cls. Feed it the point
returned by GetEntity and it will return a point that is actually *on*
the line.
Message 6 of 16
...oops -- i guess i didn't need to include that "Distance" function....
when i was writing it, i was going in another direction of comparing the
point picked and seeing which end was closer.
Message 7 of 16
Hi Frank,
Ok I have never worked with class modules to this point, so could you give
me a bit of background on how I would go about getting this to work? I have
the CURVE.cls and the VLAX.cls loaded intoVBA in two separate Class modules.
I am getting the following in both of the class modules to highlight red:
VERSION 1.0 CLASS
Attribute VB_Name = "Curve"
Attribute VB_GlobalNameSpace = False
Attribute VB_Creatable = False
Attribute VB_PredeclaredId = False
Attribute VB_Exposed = False
and
VERSION 1.0 CLASS
Attribute VB_Name = "VLAX"
The above all highlight red in the code window. Do I call the
GetClosestPointTo the same way I would in a function?
Thanx,
Rob
"Frank Oquendo" wrote in message
news:E2DF479A1CAD785BFFCD8FC44FB566BC@in.WebX.maYIadrTaRb...
> the line.
Message 8 of 16
... and the entity selection part should say "Select the opening start
point..." -- again, left over from my first attempt.
Message 9 of 16
Send me a personal email (remove the NOSPAM) reminding me to post a
VBA-friendly version of VLAX. VBA modules work fine in VB but VB
modules have a lot of extra hidden code in them that VBA chikes on.
Delete all the red stuff.
As for using the GetClosestPointTo method, it's not that
straightforward. First, create a Curve object. Then set the curve's
Entity property using the entity selected by the user:
Dim c As Curve, newPt, retval(0 To 2) As Double
Set c = New Curve
Set c.Entity =
newPt = c.GetClosestPointTo()
retval(0) = newPt(0)
retval(1) = newPt(1)
retval(2) = newPt(2)
While you're emailing me, remind me to fix the GetClosestPointTo
method (and all point-related Curve function) to return a point that
won't require any massaging.
news:906F326DBBC6AE573A40F16C6EDB8CBD@in.WebX.maYIadrTaRb...
> Hi Frank,
you give
I have
modules.
red:
> VERSION 1.0 CLASS
> and
> VERSION 1.0 CLASS
> Thanx,
> Rob
*on*
> > the line.
Message 10 of 16
Hi Lanny,
That works great... although I am still intrigued by Franks Curve.cls as it
has a bunch of functionality that I could use all over. Wish me luck!
Rob
"Lanny Schiele" wrote in message
news:83014DB5EE7741C484CCE9407B55829D@in.WebX.maYIadrTaRb...
Message 11 of 16
... hey -- my code is where you (and whoever comes across it) needs the
luck -- at least Frank knows what he's doing!
it
Message 12 of 16
Hey Frank -- for whatever reason, the applet at your website wasn't working
on my machine for quite sometime, but i visited today and it worked.
Anyway, i just wanted to see what this VLAX class was about -- WHOA! --
some cool code you got going there. I'll be using it as well as the Curve
class to get around whatever obstacles VBA presents. = )
Message 13 of 16
Rob, Why not just use GetEntity? Once you have the line, use either the
EndPoint property or StartPoint property to get your point, assuming it does
not matter which point was picked - forget the osnap.
Jacob Dinardi
Rob Outman wrote in message
Hi Frank,
VERSION 1.0 CLASS
and
VERSION 1.0 CLASS
Thanx,
Rob
> the line.
Message 14 of 16
Hi Jacob,
Actually, the point needs to be somewhere on the line very near to where the
user picked. With GetEntity, I have noticed that the point sometimes falls
off of the line (especially when the pickbox is large!)
Rob
"Jacob Dinardi" wrote in message
news:5E96CD0A09AFF7FEC47B346A613DE7EB@in.WebX.maYIadrTaRb...
does
> Regards,
> Jacob Dinardi
> Hi Frank,
have
modules.
> VERSION 1.0 CLASS
> and
> VERSION 1.0 CLASS
> Thanx,
> Rob
> > the line.
Message 15 of 16
Instead of using the point returned by the function, use a property of the
line. What are you doing with this point anyway? I remember it from your
routine the other day - I thought it was strange that nearest was locked up.
JD
news:B98D80C31F1E967CBBE70BE14DA72CFC@in.WebX.maYIadrTaRb...
Hi Jacob,
Rob
does
> Regards,
> Jacob Dinardi
> Hi Frank,
have
modules.
> VERSION 1.0 CLASS
> and
> VERSION 1.0 CLASS
> Thanx,
> Rob
> > the line.
Message 16 of 16
Jacob,
If you remember the routine, then you probably noticed that the user had to
pick the hinge point of the door and then select the same line again in
order to get the line properties. This added one more click to the routine
that I really don't think is necessary, and that the users don't like, so I
am trying to make it so the user only has to pick once for the hingepoint
instead of twice. I need the line properties in order to erase the old
lines and add the new ones. The hingepoint does not have to be at the exact
point the user selects, but it should be close. I use nearest because our
drawings do not require that much accuracy. We just place a door in a
general location. Later I will add a function to allow the user to enter a
jamb distance and actually place the door the distance entered from a
certain endpoint (if that makes sense!)
Hope that helps explain what I am trying to accomplish.
Rob
news:5405B649F8EEBC3FF9C7E88CC5A32EE2@in.WebX.maYIadrTaRb...
up.
> JD
> Hi Jacob,
the
falls
> Rob
> does
> > Regards,
> > Jacob Dinardi
> > Hi Frank,
give
> have
> modules.
red:
> > VERSION 1.0 CLASS
> > and
> > VERSION 1.0 CLASS
> > Thanx,
> > Rob
> > > the line.
