Pointing to last added block (GetAttributes) and indexing blocks automatically
Message 1 of 1
Pos.1
How can I point to the last added block to get attributes ?
Pos.2
I have following codes to put certain attribute all blocks that are added during the session. Yet,it does not function.
In following order:
1. User adds or copy's block to drawing
2. I try to add attribute (Ind comes from indexed register)
3. New attribute with index is to be added to prev. block
And, if possible attribute should be at the same area as
then block - not at position of 0,0,0.
Pasi
Dim bRefObj As AcadBlockReference
Dim entArray() As AcadEntity
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If CommandName = "ATTEDIT" Or CommandName = "ERASE" Then
Ind = 101 ' test index
a = AddAttributes(Ind)
Select Case CommandName
' Case "ATTEDIT":
' If ind=0 Then AddObjectsToBlock (bRefObj)
Case "COPY": AddObjectsToBlock (bRefObj)
End Select
SendKeys "{Esc}"
End Sub
Public Function AddAttributes(Ind As Integer) As AcadEntity
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim insertionPoint(0 To 2) As Double
Dim tag As String
Dim value As String
Dim cL As AcadLayer
Set cL = ThisDrawing.ActiveLayer
height = 1#
mode = acAttributeModeInvisible
prompt = "IB"
insertionPoint(0) = 0#
insertionPoint(1) = 0#
insertionPoint(2) = 0#
tag = "IB"
value = Str(Ind)
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
ThisDrawing.ActiveLayer = cL
End Function
Public Sub AddObjectsToBlock(blkRef As AcadBlockReference, entArray() As AcadEntity)
Dim blkDef As AcadBlock, origin(0 To 2) As Double, i As Long
origin(0) = 0: origin(1) = 0: origin(2) = 0
Set blkDef = ThisDrawing.Blocks(blkRef.Name)
For i = LBound(entArray) To UBound(entArray)
entArray(i).Move blkRef.insertionPoint, origin
Next
ThisDrawing.CopyObjects entArray, blkDef
If delObj Then
entArray(i).Delete
Next
End Sub
Replies (0)
