point array class property - how?
have scoured google for an hour and cant' find a mention of this:
how to store a point value as a property of a class
with this in the declarations section of a class module
Private mWeldDefPt(2) As Double
I tried this: (bombed on class creation)
Property Let DefPt(val() As Double)
mWeldDefPt(0) = val(0)
mWeldDefPt(1) = val(1)
mWeldDefPt(2) = val(2)
End Property
Property Get DefPt() As Double
DefPt(0) = mWeldDefPt(0)
DefPt(1) = mWeldDefPt(1)
DefPt(2) = mWeldDefPt(2)
End Property
then I tried:
Property Let DefPt(val As Variant)
End Property
Property Get DefPt() As Variant
End Property
that allowed the class to be created several times during further debug
testing
but I wasn't accessing the property
as soon as I tried to access the property thus:
in class initialize:
mWeldDefPt(0) = 0
mWeldDefPt(1) = 0
mWeldDefPt(2) = 0
in the calling sub that creates the class:
Debug.Print "DefPt is: " & ws.DefPt(0) & ", " & ws.DefPt(1) & ", " &
ws.DefPt(2)
I got:
got out of stack space error:
then I tried:
Private mWeldDefPt As Variant
and that gives type mismatch on class creation
what's the trick to get a point value as a class property?
The trick is that even though AutoCAD expects you to pass an array of
doubles for a point, you will always *receive* a variant containing an
array of variants, not doubles. If you plan on stuffing your double
array, you need to convert each element to a double.
The easy way out is to declare your member variable as a Variant.
"It's more important that you know how to find the answer than to have
the answer." - Me
Thanks again, Frank!
"Frank Oquendo" wrote in message
news:46D63F7A371CA9DDF1A361BFDDD129A4@in.WebX.maYIadrTaRb...
> the answer." - Me
and another curiousity
why did that cause a stack overflow instead of a type mismatch?
I understand very little about the stack - other than it's an area of memory
devoted to acad's use...
