Plot to pdf automaticaly using acwindow as a plotType
wianeh6700
wianeh6700
Hi, I have to create a VBA macro for AutoCAD, but I'm no VBA expert.
The main purpose of the code is to plot dwg files to pdf file automatically
I want to use the acwindow as a plot type but I want the conversion to be automatic
So far I worked on this code, but you still have to insert the corners manually
code:
Public Sub Example_SetWindowToPlot()
  Dim pdfFile As String
  pdfFile = "D:\stage\output.pdf"
  AppActivate ThisDrawing.Application.Caption
  Dim point1 As Variant, point2 As Variant
  ' Get first point in window
  point1 = ThisDrawing.Utility.GetPoint(, "Click the lower-left of the window to plot.")
  ReDim Preserve point1(0 To 1)
  ' Get second point in window
  point2 = ThisDrawing.Utility.GetPoint(, "Click the upper-right of the window to plot.")
  ReDim Preserve point2(0 To 1)
  ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2
  ' Read back window information
  ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2
  MsgBox "Press any key to plot the following window:" & vbCrLf & vbCrLf & _
     "Lower Left: " & point1(0) & ", " & point1(1) & vbCrLf & _
     "Upper Right: " & point2(0) & ", " & point2(1)
  ThisDrawing.ActiveLayout.PlotType = acWindow
  ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3"
  ThisDrawing.ActiveLayout.CanonicalMediaName = "ISO_A4_(210.00_x_297.00_mm)"
  ThisDrawing.ActiveLayout.CenterPlot = True
  ThisDrawing.ActiveLayout.StandardScale = acScaleToFit
  Dim result As Boolean
  result = ThisDrawing.Plot.PlotToFile(pdfFile)
  If result Then
    MsgBox "Plotting to pdf file succeeded."
  Else
    MsgBox "Plotting to pdf file failed."
End Sub
Alfred.NESWADBA
Well, how could the coordinates be found by your program?
When you ask the user to input lower left point ... how is the user specifying this point?
Do any rules exist to find this point automatically?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
wianeh6700
Hi, thank u for answering
I'm wondering if i can draw a frame or create a layer that contains the limits, is this possible ??
Alfred.NESWADBA
Yes, then you need to either create a selection-set for polylines on this layer (or scan the model-space for such items), then get the extents of these polylines and use them to evaluate lower-left and upper-right point.
- alfred -
Alfred NESWADBA
maratovich
It may be easier for you to use a ready-made solution - Revers
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
