plot.log
plot.log
plot.log
i would like to have acad not to litter around in my network with tons of
files of "plot.log."
can i turn the plot log off using vba? thanks
Taken from the VBA help file
Sub Example_AutomaticPlotLog()
' This example sets the AutoCAD Options dialog box
' setting Automatically Save Plot and Publish Log to True.
Dim MyPreference As IAcadPreferencesOutput2
Set MyPreference = AcadApplication.Preferences.Output
MyPreference.AutomaticPlotLog = True
End Sub
"SDren" wrote in message
news:6140121@discussion.autodesk.com...
Thanks, Larry
It was pointing to the right direction, but it was for
PlotandPublishLog.CSV, not for plot.log.
Besides, what is IAcadPreferencesOutput2? i dont have it on my computer with
Acad 2009.
"Larry" <-> wrote in message news:6140396@discussion.autodesk.com...
End Sub
I'm using ADT 2007
It appears that there is an error in the help file. It should be
"AcadPreferncesOutput"
You are correct. That is just for the .csv file. I have went to options and
turned on and off the "Plot and publish log file" and I end up with a
plot.log file no matter what the setting is. Guess I have some more
researching to do. Do you know how to stop getting the plot.log file without
VBA?
I'm with you, I don't want all these plot.log files.
news:6141338@discussion.autodesk.com...
Thanks, Larry
Acad 2009.
End Sub
Found it. Go to Options>Plot and Publish>Plot Stamp Setting>Advanced then
uncheck Create a log file.
Did a quick look through the VBA help and the object browser, and couldn't
find anything dealing with the plot stamp. So I can't help you. Sorry
Did find this in the AutoCad 2006 forum.
http://discussion.autodesk.com/forums/thread.jspa?threadID=443718
"Add this little routine to your user's startup files:
(command "-plotstamp" "Log" "no" "plot.log" "")
- Sean D. Burke"
Larry
