Please help VBA Newbe with second project ever.
mid-awe
Message 1 of 25
mid-awe
Hey all,
I'm struggling with learning the most basic VBA concepts. I know how to program from my experience with LISP and the old BASIC so the handling of variables and stuff is easy for me but I need to know how to get the user's input from a text box and store it as a variable that I'll show in the dialogue in a label. I have labels 1 through 119 and I'll increment the numbers as data is entered by a control button. Now when this button is clicked or enter is pressed on the keyboard I'd like to get the value or whatever it's called from the textbox and assign that value to the appropriate label.
Can anyone please help. Thanks in advance.
Replies (24)
Message 2 of 25
Maybe I’m missing something but it sounds like what you want to do is something like
Variable = TextBox.Text
Label.caption = variable.
Message 3 of 25
mid-awe
I'll give it a try thanks.
Message 4 of 25
mid-awe
I also think that I'm going to have to use a variable as a name of a variable. I'm sure that is probably confusion so I'll explain. I need the names of the labels to increment each time data is entered into the textbox and the command button is clicked. example:
J48591 = first click becomes label1.caption
J48639 = second click becomes label2.caption
J46320 = third click becomes label3.caption
etc.,etc.
can I just use a variable.lable ? or is there some other way?
Am I going to have to create an array?
Message 5 of 25
In general (and certainly not with the programming skills of a learner) VBA
controls cannot be renamed.
You could put 120 labels in the same place and control their visibility with
code, so that only one is visible by use Previous and Next controls - and
each time these controls are used, read the value to an array based on a
counter. These controls have a reference number in the control set of the
form. Hence you could do some along the lines of this psuedo code
For i = x to y
Form.Item( i).visible = false
next i
Form.Item( counter).visible = true
You could also use a list box holding the counter number and use it to
control the visibility of the text boxes.
I would include a label which describes what that particular texzt box is
requiring for data entry.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:4930195@discussion.autodesk.com...
etc.,etc.
Message 6 of 25
mid-awe
I'm not really trying to change the visibility of the labels but it's a good idea. What I want is to have the data sent to the label after button clicking. I need the program to know that if the last data was sent to label1 then the next time the button is clicked it should be sent to label2 and so on. below is what I have so far:
[code]Dim Varcnt As Variant
Dim LblVar As Variant
Dim JNUM As Variant
Public Sub MutiPlot()
Varcnt = 1
End Sub
Private Sub Label1_Click()
Label1.Caption = JNUM
JNUM = DataEnter.Text
End Sub
Private Sub Lst_Add_Click()
Set LblVar = "Label" + Varcnt
LblVar.Caption = JNUM
Varcnt = Varcnt + 1
End Sub[/code]
This of course give me and error but I am unable to correct it.
Thanks for all your help
Message 7 of 25
too bad vba does not support control arrays
one could try something like
Dim ctl As Object
Dim i As Integer
i = 1
For Each ctl In Me.Controls
If TypeOf ctl Is Label Then
If ctl.Name = "Label" & i Then
ctl.Caption = "Label caption " & i
i = i + 1
Next ctl
But since you have over 100 labels (yikes!?!)
that's not a very elegant solution
hopefully someone can do better
Mark
wrote in message news:4930325@discussion.autodesk.com...
Message 8 of 25
mid-awe
The 119 labels are for the 119 job numbers that I'm allowing the user to type in before running the remainder of code. The user must be able to view a complete list of the numbers that they type in and make changes if necessary before continuing the code. I would do more than 119 if a reasonably sized dialogue could fit them in.
Thanks for the suggestion I'll try it.
Message 9 of 25
mid-awe
Sorry, I only received an error stating that the object doesn't support this property or method.
Any other suggestions?
Thanks in advance.
Message 10 of 25
Here is another idea. Class is light, just a sample. Something
to play with anyway.
sorry if this goes through more than once.
wrote in message news:4930359@discussion.autodesk.com...
property or method.
Thanks in advance.
Message 11 of 25
user has to type in 119 job numbers to start?
are you sure a combo box or list box wouldn't work?
a scroll bar will appear when the contents exceed the size of box
you can also design the form to be resizable if need be.
I'm only suggesting to consider various alternatives to your user interface
before going too far down a very unusual path.
not to be critical but the use of labels for this seems very different from
the usual dialog interface.
Does the user have to type all the data in?
you cant select from a pre-filled list? a directory of folders?
just trying to throw out ideas
hth
Mark
wrote in message news:4930358@discussion.autodesk.com...
Message 12 of 25
what line is the error on?
Mark
property or method.
Thanks in advance.
Message 13 of 25
I'm agreeing with Mark.
As well, consider that any form of user input which requires the user to
type in 100+ items of data is an almost certain guarantee of user input
error.
Can you plan to populate your fields with some sort of data (maybe the last
used data set) and have the user only need to edit the changed ones?
Laurie Comerford
www.cadapps.com.au
"MP" wrote in message
news:4930435@discussion.autodesk.com...
hth
Mark
Message 14 of 25
mid-awe
Ok, it's working now except it only updates the label1 and none of the others. I can click as often as I like but it still assigns the data to label1. any ideas?
Message 15 of 25
mid-awe
I'm sorry if I miscomunicated. It allows the user to type in up to 119 Job numbers before they are forced to run the code. If they only type in one Job number it should also work. But it may happen that they will have 200 job numbers at times and they can only run the code for 119 at a time.
Message 16 of 25
>Case -2147024809
>clickCounter.CounterValue = 1
Resume CommandButton1_Click_Exit
I forgot this statement here.
"Paul Richardson" wrote in message
news:4930419@discussion.autodesk.com...
property or method.
Thanks in advance.
Message 17 of 25
mid-awe
Thanks, I'll give it a try.
Message 18 of 25
I think that because you're coming from LISP, you may
be approaching the design of your UI with the limitations
of what you're used to, which IMO, is a mistake.
The 120 label thing is certainly not the way to go, although
that might be the only avenue if you were using LISP/DCL,
but you're not in DCL purgatory any longer with VBA.
First you should forget about the limitations and constraints
that you're used to designing user interfaces with, and look
at what else VBA has to offer.
Given what you've described so for, it's fairly obvious that
your interface needs to be some type of grid or listview,
that has two columns, one or both of which are editable.
If you are writing code for others, then they deserve better
than a VBA application with a user interface that suffers
from the the inherent (and quite rediculous, if I may say so)
constraints of LISP/DCL.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4930455@discussion.autodesk.com...
Message 19 of 25
mid-awe
Thanks. I see you example works great., but when I try to apply it to my program it doesn't work. I have all of my labels in a separate frame from the frame that hold the command button. Is this possibly why it fails and what can I do to fix it?
Thanks again.
Message 20 of 25
the program looks for Label1-Label...
You would need to edit for your label
names. I would just use it as an example
and take the advice of others here in your
design.
wrote in message news:4931237@discussion.autodesk.com...
Thanks again.
