PickfirstSelectionSet
Message 1 of 16
I have a little problem, i like to use the PickfirstSelectionSet.
When you select the objects before you start the program you will see the grips and the selection.
Now i want to clear the grips and the selection.
Is this possible with VBA? I could't find anything, maybe it is possible with vlisp?
Replies (15)
Message 2 of 16
OK, i forgot to tell you a little bit more.
I want to start the vba-program with a button on a toolbar
First i created a, for example, Test.mnu
I have an Button like this
ID_CopyLayCurr [_Button("Copy to current Layer", "CopyLayCurr.bmp",
"CopyLayCurr.bmp")]^C^CCoLayCur;
and a Test.mnl with this
(defun c:CoLayCur (/) (vla-runmacro(vlax-get-acad-object) "acad.dvb!modify.CopyLayerCurrent"))
When i select some objects befor the command, the objects will be selected
after the command.
What do i have to do that i can use the pickfirstselectionset with a toolbar?
Message 3 of 16
Will the "ActiveSelectionSet" property help. Here are some things you can do
with it.
Gary
Dim oEnt As AcadEntity
MsgBox ThisDrawing.ActiveSelectionSet.Count
ThisDrawing.ActiveSelectionSet.Highlight False
ThisDrawing.ActiveSelectionSet.Clear
For Each oEnt In ThisDrawing.ActiveSelectionSet
ThisDrawing.ActiveSelectionSet.RemoveItems oEnt
Next
ThisDrawing.ActiveSelectionSet.Erase
Message 4 of 16
Hallo Gary,
this is not the answer to this problem, sorry.
The ActiveSelectionSet returns the same as the PickfirstSelectionSet.
The problem is, that i don't know how to start a vbaprogramm with a button at
the toolbar.
When i set a command with
the command starts with the selection but the selection will not be cleared
after the command.
When i use following to set a command
(defun c:colaycur (/) (command "_-vbarun" "modify.CopyLayerCurrent"))
the selection will be cleared and i have to select the objects again.
Therefore my question, i can not believe that there is no one who had this
problem before.
I try to find a solution since four days but nobody could help me till today.
So please HELP me.
Message 5 of 16
Roland,
I don't use vlisp very much, but I don't think you need the statement:
I always use vl-vbarun, something like this:
(defun c:CL1 (/) (vl-vbarun "modify.CopyLayerCurrent"))
A VBA program can be loaded (without the pesky dialog box) something like
this:
(vl-vbaload "C:\\Test\\My_VBA_Program.dvb")
I'm not sure I fully understand your problem but I hope this helps.
Gary
Message 6 of 16
Roland,
I believe you are out of luck on this with what's
currently available in the VBA object model. You can look into the .Highlight
method for selection sets, but I think you will find (as I did) that this does
not sufficiently 'deselect' objects. The objects will be deselected, but the
grips will still be visible (akin to hitting the escape key only once in 2002
products). I experience the same behavior you see, and have looked for a work
around too. Seems like we need a .Gripped property that we could set to false at
the end of a macro in order to make this work.
size=2>
Kevin
Hallo Gary,
  The
  the toolbar.
  the command starts
  after
the command.
  (defun c:colaycur
  the
  problem before.
So please HELP me.
Message 7 of 16
heres a notes i found in past posts here via google, author unknown
"vla-runmacro will prevent you from picking on screen while a userform is
hidden
as you say. As I understand it, this is because it causes your VBA macro to
be
run in the application context rather than in the document context. If you
need
to be able to do this, the easiest fix is to use vl-vbarun. However, there
are
a couple of important points to note:
vla-runmacro is the only method I am aware of that will allow you to use the
PickFirstSelectionSet, and it is also the only method I know of that will
allow
you to click a toolbar button while running a vba macro without crashing the
macro."
basically i don't think they have any good way to start vba from lisp.
either way you use has problems, too many print statements on command line
etc....
sadly it doesn't seem like they plan to fix any of it in the near future
either.
if you just need to clear your selection set you can (ssgetfirst nil nil) at
the end of your lisp.
hth
mark
"RolandF" wrote in message
news:f1969ec.2@WebX.maYIadrTaRb...
> Hallo Gary,
> So please HELP me.
Message 8 of 16
Thank you to all.
Isn't it crazy, there is a pickfirstSelectionSet and you can not do anything with it.
Is it possible to use (ssgetfirst nil nil) at the end of an vbaprogramm in any way?
Message 9 of 16
It should be (ssseetfirst nil nil), and you can do
it like this:
    ThisDrawing.SendCommand
"(sssetfirst nil nil)" & vbLf
size=2>
Kevin
Thank
you to all.
Message 10 of 16
I believe the author was me, and I only got it half right. vla-runmacro
actually executes your macro in the DOCUMENT context (not the application
context). *hangs head*
Note to self: If you only think you know the answer, don't post. 😃
"Mark Propst" wrote in message
news:412CA64AC804AD6E874EB5EF76622BE6@in.WebX.maYIadrTaRb...
> hidden
> be
> need
> are
> allow
> macro."
> etc....
> either.
> hth
> mark
> > Hallo Gary,
> > So please HELP me.
Message 11 of 16
I disagree. The rest of the group can tell me if I need to change my
position. There have been several times where I've almost held my tongue
because it wasn't my area of expertise, but my answer then helped the person
find the rest of the answer, or triggered someone more knowledgeable to
rebut my half-truth, and thus answer the original question....
I say since it's a discussion group and not a classroom, if you think you're
reasonably close to right, fire away....
Message 12 of 16
Thank you, Terry.
The command can be also (sssetfirst nil).
But, is it possible to send this command without sendcommand.
Because when i do it with sendcommand i will get two lines in the commandline which maybe confuse some users.
If it is not possible, it is OK. I just want to know.
Roland
Message 13 of 16
I don't know of a way offhand using vba/lisp right
out of the box. You might have a look at
href="http://www.acadx.com">http://www.acadx.com
, look for
VLAX.
Kevin
Thank
you, Terry.
But, is it
some users.
know.
Roland
Message 14 of 16
I know AcadX, it is a great tool, would like to have it for 2004, hope it comes soon.
But i think i've got it. Here is the answer:
(defun c:CoLayCur (/) (vla-runmacro(vlax-get-acad-object) "acad.dvb!modify.CopyLayerCurrent")(sssetfirst nil)(princ))
Roland
Message 15 of 16
good idea Roland - thanks for sharing
Kevin
I
soon.
nil)(princ))
Roland
Message 16 of 16
OK, i am back again. I hope that there was someone interested in this post.
No i think i know a little bit more about preselecting.
  • Do not use the PICKFIRSTSELECTIONSET if you want to use the selected items
  • Just use the SS.SelectOnScreen FilterType, FiterData
  • and use i.e. (defun c:CoLayCur (/) (vla-runmacro(vlax-get-acad-object) "acad.dvb!modify.CopyLayerCurrent"))
    for the toolbar-button
Like you see at the comments above, if you use PickfirstSelectionSet and vla-runmacro,
the previous selection will not be cleared after the command.
If you use a nomal SelectionSet you can use Filter or not, and the best, the
objects you've selected before will be deselect automatically after the command.
It's great, isn't it?
Roland
