Pause Symbol
Pause Symbol
Message 1 of 15
Pause Symbol
From the Visual Basic help files of VB Design
http://vbdesign.hypermart.net/cadpages/
Hi Tom,
Without seeing the code you have so far, I offer you this:
ThisDrawing.Utility.GetAngle
This will allow the user to enter a number at the command line or pick on
the screen (and it will "pause" code execution until it gets the value)
Randall Rath
VB Design
Replies (14)
Message 2 of 15
Someone here wrote a Lisp routine that looks something like this:
(defun C:Curbs ()
(defun CURBR ()
(command "insert" "TCBCR" insp (getvar "ltscale") "" pause (rtos
TC)
(rtos BC) (princ)
;; Begin Main Program
;;Stuff here to get ins pt , desc info, elev etc & calc TC & BC
values
call CURBR
(princ)
I can do everything in VBA except the pause to allow the user to specify
an arbitrary rotation. Is there a way to do this in VBA (A2k - LDD2)?
Thanks - Tom
Message 3 of 15
Randall,
Here's the code.
Private Sub insertBlock(blkName As String)
Dim oInsPt As Variant 'User selected insertion point
Dim vAttributes As Variant 'Insertion Block Attributes
Dim vScale As Variant
Dim oBlock As AcadBlockReference
Dim oLine As AcadLine
On Error Resume Next
vScale = ThisDrawing.GetVariable("ltscale")
Me.Hide
oInsPt = ThisDrawing.Utility.GetPoint(, vbCr & "Select Insertion
Point: ")
If Err.Number = 0 Then
Set oBlock = ThisDrawing.ModelSpace.insertBlock(oInsPt, blkName,
vScale, vScale, 1, 0)
vAttributes = oBlock.GetAttributes
vAttributes(0).TextString = txtTop.Text
vAttributes(1).TextString = TxtBottom.Text
Set oLine = ThisDrawing.ModelSpace.AddLine(TB_Curbs.oPt, oInsPt)
Set oInsPt = Nothing
Set vAttributes = Nothing
Set vScale = Nothing
Set oBlock = Nothing
Set oLine = Nothing
End Sub
I can't see a way of interrupting Set oBlock in order to get user
input. There is some mention in the Help about using the \
character with macros but I couldn't make that work either.
- Tom
Randall Rath wrote in message
news:88rq2d$pko9@adesknews2.autodesk.com...
> Hi Tom,
Message 4 of 15
Hi Frank,
I covered all of the system variables for R15 sometime ago..I think it was
last October. If you look in the A.C.A.D. Archives you can find a complete
documentation with sample code for each.
I love the name on that one
Randall Rath
Message 5 of 15
Hi Frank,
Marie handles all of that stuff now, she must not have read my sticky note!
If you are still not getting the letter I suggest you re-subscribe,
http://vbdesign.hypermart.net/cadpages/a_code_a_day_acad.htm
that way it will go directly to the boss.
Randall
Message 6 of 15
Speaking of which, have you stopped cranking out A.C.A.D. or have you just
lost my address due to my ISP Shuffle?
Visit me at: http://www2.stonemedia.com/franko
"Randall Rath" wrote in message
news:88s2f4$pl233@adesknews2.autodesk.com...
> Hi Frank,
complete
> Randall Rath
Message 7 of 15
Hi Tom,
Is there any reason why you can't retrieve the value prior to that line?
Randall Rath
VB Design
Message 8 of 15
Randall,
Works like a champ. Of course, I'll get some blank stares from the users
because the won't see the actual block being highlighted. They'll have
to just get used to it.
One more question if you don't mind. I see the following on the command
history:
Pick a Point:
Command: Select Insertion Point:
Command: Select Rotation:
Command: Duplicate definition of block ADCADD_ZZ ignored.
Pick a Point: *Cancel*
Is there a way to suppress the Duplicate Definition message? As you can
tell, I'm still in AutoCad 101.
Thanks - Tom
news:88rro0$pkp11@adesknews2.autodesk.com...
> Hi Tom,
line?
> Randall Rath
> VB Design
Message 9 of 15
Hi Tom,
Change the value of the system variable NOMUTT (yes that is the real name)
to 1
This will supress messages to the command line, just be sure to return it to
its normal state when you are done!
Randall Rath
VB Design
Message 9 of 15
You can also use the SendCommand with the insert. You need to quote all
commands. This example inserts the block and you can see it while you
rotate it.
Sub vbinsert()
Dim strTest As String
Dim strIns As String
' strTest id a block in the drawing to insert
strTest = "recp"
strIns = "(command " & """-insert"" " & """" & strTest & """" & " pause
" _
& """1.0""" & " """") " & vbCr
ThisDrawing.SendCommand strIns
End Sub
Hope this works.
Bill Brookman
bb@brookmangroup.com
Tom Gilmer wrote in message
news:88rvag$plh17@adesknews2.autodesk.com...
> Randall,
> history:
> Pick a Point:
> Thanks - Tom
> > Hi Tom,
> line?
> > Randall Rath
> > VB Design
Message 11 of 15
Where did you ever come across that one???
news:88s1pt$pli41@adesknews2.autodesk.com...
> Hi Tom,
> to 1
to
Message 11 of 15
Randall,
Thanks for all your help. I've doing a lot of muttering these days.
- Tom
> Hi Tom,
name)
> to 1
Message 11 of 15
Bill,
I'll try it as soon as I get a chance. I'll let you know how it went
Thanks - Tom
Bill Brookman wrote in message
news:88s0ls$plg22@adesknews2.autodesk.com...
all
> rotate it.
Message 14 of 15
Credit where credit due.
I do believe this was first documented by Owen Wengerd.
http://www.manusoft.com/acadexp.htm#SysVars
__________________________________
Michael Puckett
programmer@cadvision.com
> Not < an Autodesk hall monitor.
Imagination makes all things possible.
"Frank Oquendo" wrote in message
news:88s223$pko26@adesknews2.autodesk.com...
> Hi Tom,
> to 1
to
Message 14 of 15
Frank, just so you know, MDT4 does not fully honor NoMutt...
R. Robert Bell, MCSE
Network Administrator (or, Modern-day Wizard)
(remove the "not." in my address for direct e-mail)
Frank Oquendo wrote in message
