Paper size for plotting question
Message 1 of 11
How do I indicate a specific paper size in VBA for a layout to be plotted?
I know that MediaName = ThisDrawing.ActiveLayout.CanonicalMediaName will
show the current papersize, but I can't seem to be able to set it to the
size I want. Any ideas or sample code would be great as this is keeping me
from completing an job.
thanks!
Replies (10)
Message 2 of 11
Hi Monica,
You have the correct property, but for the change to take effect you MUS use
the Regen method of the Active Document (VBA = ThisDrawing).
A simple example? Sure thing:
Public Sub Set2Legal()
Dim objLO As AcadLayout
Set objLO = ThisDrawing.ActiveLayout
objLO.CanonicalMediaName = "Legal"
'are you missing this line?
ThisDrawing.Regen acActiveViewport
End Sub
Randall Rath
Message 3 of 11
Hello monica and randall.
.CanonicalMediaName = "Your Papersize"
.RefreshPlotDeviceInfo
Has this the same effect to you as forcing a regen? I use this in my custom
plot program and it never gives problems.
Greetings,
Henk
CadFancy - Adventures in Visual Basic
www.CadFancy.myweb.nl
Message 4 of 11
Hi Henk,
It depends on your needs! By using the regen you see the change in the
drawing. The Refresh plot device info applies the change, but does not
change the layout on the screen.
So, they are different. Does that mean you should change? Not if what you
have works for you!
Randall Rath
Message 5 of 11
Ah, I think I understand now, I even discovered I had a problem there too.
When my program created a new layout with it's custom plotsettings and the
scale was set to acScaleToFit, the final visual result was poor: The black
background didn't fit with the paperboundary. Even with a manual regen
nothing changed, although the result of my plotexample sub was good. Only
with opening the PageSetup dialog directly followed with Ok the background
fits.
I found a weird solution to this: after programmatically regenerating the
drawing, and before a ZoomAll I cal the .StandardScale property for the
second time like this:
If Thisdrawing.ActiveLayout.StandardScale = acScaleToFit Then
A strange solution, but it works
Greetings,
Henk
Message 6 of 11
Actually, I'm having a different problem. I want to set the new papersize
to plot in the statement:
ThisDrawing.Layouts("Mysheet").CanonicalMediaName = "(22.00 x 34.00)"
I keep getting errors though. Any ideas?
"Henk Loonstra" wrote in message
news:D24B87C5DC8D2D110E8F1650B65180EF@in.WebX.maYIadrTaRb...
> fits.
> End If
> Greetings,
> Henk
Message 7 of 11
Are you sure the name "(22.00 x 34.00)" is the right name for your
papersize?
Maybe you should check it with:
1. Setting the papersize active with the Plot dialog
2. Debug.Print Thisdrawing.ActiveLayout.CanonicalMediaName
By the way, what errormessages do you get?
Greetings,
Henk
Monica Eisfeld schreef in berichtnieuws
3A4D77AA5DDB3748BC1C51AFBF1EA430@in.WebX.maYIadrTaRb...
Message 8 of 11
The error message I get is "invalid input". If I use the statement
strMedia=ThisDrawing.ActiveLayout.CanonicalMediaName I get "11x17". Yet if
I use ThisDrawing.Layouts("MyLayout").CanonicalMediaName = "11x17" I get the
error. This seems really strange since it's the exact same string!! I'm at
a total loss here.
news:B02188DEF817DBC5E48B1DD53AA17C99@in.WebX.maYIadrTaRb...
> papersize?
> Greetings,
> Henk
papersize
Message 9 of 11
Monica I just wrote a new thread stating the exact problem you describe. I
cant assign .CanonicalMediaName or .ConfigName without getting "invalid
input"
My code looks like:
Set Layout = myFile.PaperSpace.Layout
With Layout
.SetWindowToPlot wmPoint1, wmPoint2
.PlotType = acWindow
.ConfigName = plotDevice
.CanonicalMediaName = plotPaper
.SetCustomScale 1, wmPlotScale
.CenterPlot = True
End With
"Monica Eisfeld" skrev i meddelandet
news:82F7DE63C29D9F2D3FD05B3617D9AF37@in.WebX.maYIadrTaRb...
if
the
at
> a total loss here.
> > papersize?
> > Greetings,
> > Henk
> papersize
34.00)"
Message 10 of 11
Monica,
I've worked around the problem!
If I call the .GetCanonicalMediaName and .GetPlotDeviceNames before trying
to assign .CanonicalMediaName and .ConfigName everything works perfectly!
Wonder why though? ;^)
Mats
"Nothing's impossible. It just takes a little longer"
mailto:mats.johansson@pqr.se
Mats Johansson
PQR Consult AB, Sweden
if
the
at
> a total loss here.
> > papersize?
> > Greetings,
> > Henk
> papersize
34.00)"
Message 11 of 11
Hi Johansson, Mats
what is the data type of wmPoint1, wmPoint2 in your code.?
