Overkill
Overkill
Overkill
Hello!
When you execute the command OVERKILL, a window appears. How to press OK using VBA?
seabrahenrique
Hello!
Consider to use the variation "-overkill" instead "overkill" in your code. (With the "-").
You also can combine that proposal with the "hadent" option in comand line, something like that:
ThisDrawing.SendCommand "_-overkill (handent """ & MyLine.Handle & """) " & vbCrLf
And then, u can "overkill" the line and press enter without the window appears.
I hope can help 🙂
@seabrahenrique Thank you! The hyphen(-) at the start of the command really helped.
