Outputting to Excel
Outputting to Excel
Outputting to Excel
This is kind of an Excel question but maybe one of you knows. I'm exporting
my BOM to excel, which works fine. I'm having trouble sorting the worksheet.
I'm trying to sort column "A" against a custom list that I made. The problem
is, it ignores the list which I'm specifying. The strange thing is even in
excel when I manually choose sort and pick my list, it will not work, but...
I notice that if I double click in a cell, or click in the formula bar, or
change a cell contents, then try to sort it works. I'm not sure if there is
a hang up or if there is something I'm not doing correctly. I even tried
recording the macro to sort from within excel and running it and it's the
same story. Any ideas?
Thanks a million.
-phix
Sorry for the belated reply, I dont get to spend alot of time going
through the newsgroup (only when I have a problem 🙂
I had a similar problem sorting in Excel when I was trying to do the
same thing as you... extract the BOM. I got so frustrated, that I ended
up putting the data into an array in code and sorting the array. Now,
before I get flamed for telling you to do it this way, let me make a
statement. If there is an available method or operation that you can
have the application accomplish, as opposed to doing it yourself, you
should go that route. However, the sorting method I used, and the
amount of data I was sorting (under 200 items), the method I used was
perfectly acceptable to my standards of getting the job done. I am not
an Excel expert, nor do I want to become one, so I chose to handle the
problem the best way I saw fit to do so. Just letting you know other
ways to look at...
Dennis Helms
> Thanks a million.
> -phix
your doing exactly what i need to do but i have no idea of where to start. any suggestions... ie... books, websites, discussion groups. we have an ERP system that will print to an excel file that i would like to use in a macro either in excel or autocad. this would than create a BOM that i can like to both. e-mail SheridanJM@aol.com
I have had very good luck with the books from WROX press. I know they make a book for Excel 2000 VBA & Acad 2000 VBA.
Matt Westveld
BC Computing, Inc.
matt@bc-computing.com
