Option Button Validate
06:41 AM
In a dialog I have 4 option buttons that when changed show stored values in a number
of different controls. If the user changes a value in one of the other controls and then
tries to change option buttons without hitting apply, I want to prompt them with a
messagebox.
Maybe some of the problems I am having are because this is in a addin dll ?? but if I
use a normal option button the validate sub fires but the click event never does. (just
like it works if you are stepping through code using the validate sub). If I change the
option buttons to graphical buttons then it works every time except the first.
The form loads, I edit a textbox which sets a Boolean to notify the validate that
something has changed, but then when I click a different option button the text change
event fires again??, and the validate doesn't. After that first time it works right.
Is there a better way to do what I want. If I put the code in the Mouse down event for
the option buttons is there any way to cancel the click event for it?
I imagine I could do it in the click event but it would take all kinds of Booleans and
checks and storing the old button name etc.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
messagebox.
Kent
Assistant Moderator
