Opening Excel from VBA
Message 1 of 8
I am attempting to open Excel and load a spreadsheet that already exists at a predefined location. I don't want to make Excel visible, however. I just need to open this spreadsheet up and use normal methods for stripping data from the cells.
I know how to get the data from the spreadsheet if Excel is already open at runtime. However, I don't want Excel to be open at runtime. Rather I think I need to ise the "CreateObject" or "GetObject" to open Excel with a spreadsheet already loaded. How is this done?
Thanks for any help...
Replies (7)
Message 2 of 8
dim Excelapp as Excel.application
on error resume next
set Excelapp = GetObject(, "Excel.Application")
if err.number > 0 then
set Excelapp = CreateObject("Excel.Application")
end if
| Rob Starz
| Stardsign cad solutions
| AEC Designer / Consultant / Developer
| iC - AEC Information Center
| www.stardsign.com/aecic.html
| "can we make it any easier?!"
Message 3 of 8
Rob, the code you displayed is what i'm using. However, no spreadsheet has been loaded. I need to load a specific spreadsheet into Excel so I can strip data from the cells for use in an AutoLISP program.....
Message 4 of 8
Excelapp.Workbooks.Open "c:\MyFile.xls"
-- Walter -- http://www.ActiveDwg.com
"David_Lister" wrote in message
news:f0aa8d6.1@WebX.maYIadrTaRb...
Message 5 of 8
Thanks Rob and Walter. Just curious though... ...I know that the Excel spreadsheet is opened and I have been able to acquire data from it easily, and this is how I want it to function. However, for troubleshooting purposes, is it possible to actually make the Excel Application visible (onscreen) during program execution. I tried using "Excelapp.Visible" (based on the above example) but this apparently gives me a compile error: Invalid use of property. Strange, I have used it before with no problems. Any ideas?
Message 6 of 8
...sorry, let me answer my own question :
Excelapp.Application.Visible = True
Message 7 of 8
Did you try it like this:
Excelapp.Visible = True
Message 8 of 8
No, I forgot the "= true" part. This method works as well. Thanks.
[Lisp programmer trying to give VBA a chance 🙂 ]
