Opening/Closing Projects in 2009
hanchris
hanchris
I cannot seem to open/close VBA projects in 2009. What could be the problem?
I searched under Help and it says to select the Open icon, which I cannot find in any menu, including the customizations. It also says you can type "Ctrl-O" but that does not work either. I also tried "Ctrl-N" and nothing happens there.
Is there a reason for this or could we have done something wrong with the installation?
Chris
If a VBA module is already loaded in the AutoCAD session: In the AutoCAD
drawing editor hit Alt-F11 to go to the VBA editor.
If a VBA module is not already loaded in the AutoCAD session: load the
module in the AutoCAD drawing editor by running the VBA manager
(_vbaman) then hit Alt-F11 to go to the VBA editor.
hanchris wrote:
> I cannot seem to open/close VBA projects in 2009. What could be the problem? I
> that does not work either. I also tried "Ctrl-N" and nothing happens there. Is
> installation? Thanks, Chris
