Opening A2k from VB - Run-time error '-2145386390 (8020006a)'
03:21 AM
I have written a program that extracts attribute data from AutoCAD
drawings to populate a database. AutoCAD is not always on when the user
starts my program. I first try to connect to AutoCAD with the following
line:
Set ACAD = GetObject(, "Autocad.Application")
If that returns an error I try:
Set ACAD = CreateObject("AutoCad.Application")
These two statements and the next few statements that set up my object
references for AutoCAD come straight out of the AutoCAD help files:
Set DOC = ACAD.ActiveDocument
Set MS = DOC.ModelSpace
Set BLOCKS = DOC.BLOCKS
Set SSET = DOC.SelectionSets
Set UTIL = DOC.Utility
The problem is that sometimes after I have launched and connected to
AutoCAD and the DOC variable has been set, almost all of the other objects
in the AutoCAD environment have "No Database". I get an error message
saying: "Run-time error '-2145386390 (8020006a)'".
How can I update the AutoCAD environment or my VB environment to reflect
the fact that I have AutoCAD running.
I can't set the MS (ModelSpace) variable. That's the first one that
causes trouble, but I'm sure the others would return the same message
because when I look at the DOC object in the watch window, "No Database" is
the value of almost all of the objects.
Any help is appreciated. Thank you.
Sincerely,
Michael Madrid
line:
Sincerely,
Michael Madrid
