open drawing without viewing
Andy73
Andy73
I am working a routine that I wblock out some blocks to self named files. I then need to open each file to do thing like convert the block attributes to text, explode the block , rename some layers, ect... Is there a way to open a document "not visible" to save on the graphics processing time. By some blocks I mean upwards of 300.
Thank you
Andy
arcticad
You have to use ObjectDBX to get the Database of the file.
{code}
Function test1()
Dim FileName As String
FileName = "c:\1.dwg"
Set ODBX = GetOdbx
On Error Resume Next
ODBX.Open FileName
If not Error = 0 Then
For Each item In ODBX.Modelspace
If TypeOf item Is AcadBlockReference Then
MsgBox item.name
Next
End Function
Function GetOdbx() As Variant
Dim ODBX As Variant
If ThisDrawing.GetVariable("acadver") = "16.1s (LMS Tech)" Then
Set ODBX = GetInterfaceObject("ObjectDBX.AxDbDocument.16")
If ThisDrawing.GetVariable("acadver") = "16.0" Then
If ThisDrawing.GetVariable("acadver") = "17.1s (LMS Tech)" Then
Set ODBX = GetInterfaceObject("ObjectDBX.AxDbDocument.17")
If ThisDrawing.GetVariable("acadver") = "17.2s (LMS Tech)" Then
Set GetOdbx = ODBX
End Function
{code}
(defun botsbuildbots() (botsbuildbots))
you could also set the regenauto variable off and application.Visible = False
