Open Autocad Drawing and then execute the program
Hi I have some coding in VBA but I want that if I click on generate drawing then new Autocad drawing should be open and then my program should run to draw the drawing.Capture1.PNG
norman.yuan
In most cases, the workflow like that would be:
1. Run a VBA macro (a public method in an VBA module);
2. The macro brings up the UserForm to collect data from user;
3. User clicks either "Generate/OK" or "Cancel" button, which hides the UserForm with someway indicates the UserForm is oked, or cancelled;
4. If the UserForm is oked, gather the user-input data from the UserForm;
5. Create new drawing with the user-input data, or use the data on existing (bland?) drawing.
So, for the UserForm, you may have a member field like this
Public oked As Boolean
Then for the "Generate" and "Cancel" button, you would have their click event handler like:
Private Sub GenerateCommandButton_Click
    If Not ValiddateUserInputs() Then '' you may want to make sure all required data are entered
        MsgBox "Some requried data missing!"
        Exit sub
    oked=True
    Me.Hide
End Sub
Private Sub CancelCommandButton_Click
    oked=False
    Me.Hide
End Sub
Then here is the VBA Macro in module:
Public Sub CreateNewDrawing()
     ' You'd better define a class to hold the data
     ' inputted by user
     Dim newDwgData As DwgData
    UserForm1.Show
    if UserForm1.oked Then
        Set newDwgData='' get from the UserForm1, it is up to your code
        CreateNewDrawing newDwgData
    End if
    Unload UserForm1
End Sub
Private Sub CreateNewDrawing(data As DwgData)
    Dim dwg As cadDocument
    Set dwg=Application.Documents.Add([template path/name])
    ''Do whatever with the AcadDocument with user-input data stored in data parameter
    dwg.SaveAs [file name]
End Sub
Norman Yuan
Drive CAD With Code
