Obtaining CAD drawing data from an unopened drawing.
Message 1 of 9
How can I get the drawing data from an unopened CAD document in VBA?
My goal is to have a form with a listbox of the files in the current
directory folder, and when a user clicks on a file in the listbox, another
listbox is populated with the names of the layouts in that drawing.
I've been unsuccessful in accessing this information unless the file is
currently open. I know that I could create a second instance of AutoCAD,
open the selected file in the background, populate the listbox with the
thisdrawing.layouts property and then quit the second running ACAD object,
but that's really memory and time intensive, and I'm sure there's another
way, because ADT 2002's Design Center Explorer can do this very thing.
Any help anyone can give me would be much appreciated. Thanks in
advance!
Kevin Mullinax
Replies (8)
Message 2 of 9
ObjectDbx
"Kevin Mullinax" wrote in message
news:8C50BD4B7B5BB67AC006ECE9644B55D1@in.WebX.maYIadrTaRb...
Message 3 of 9
to elaborate slightly..
"Mark Propst" wrote in message
news:B8B464DF43DF35B8B122AC89DC5344A0@in.WebX.maYIadrTaRb...
> ObjectDbx
Option Explicit
'must have reference to ObjectDBX 1.0 Type Library set in Tools|References
'object dbx must be registered on each computer on which this sub is to run
' Based on example by Jimmy B 2000-03-08
' Runs in AutoCAD 2000 with axdb15.dll (must be referenced)
' Example of listing all layouts on all drawings in a directory.
' prints filename and layout names to textscreen of current document
Private Sub ListLayouts()
Dim oDbx As AxDbDocument
Set oDbx = GetInterfaceObject("ObjectDBX.AxDbDocument")
Dim oLyt As AXDB15Lib.AcadLayout
Dim sPath As String
Dim sFileName As String
Dim sFullName As String
'******** put your path here *********
'sPath = "C:\DirectoryWithDrawingFiles"
sFileName = Dir$(sPath & "\*.dwg")
Do While sFileName <> ""
ThisDrawing.Utility.Prompt vbCrLf & String(Len(sFileName) / 2, "-") &
"Layout list for" & String(Len(sFileName) / 2, "-")
ThisDrawing.Utility.Prompt vbCrLf & "File: " & sFileName
ThisDrawing.Utility.Prompt vbCrLf & String(Len(sFileName) + 15, "-")
sFullName = sPath & "\" & sFileName
On Error Resume Next
oDbx.Open sFullName
If Err Then
'drawing probably needs recovery
ThisDrawing.Utility.Prompt vbCrLf & sFullName & " *** unable to
open ***"
Err.Clear
Else
For Each oLyt In oDbx.Layouts
ThisDrawing.Utility.Prompt vbCrLf & oLyt.Name
Next
Set oLyt = Nothing
sFileName = Dir$
Loop
Set oDbx = Nothing
End Sub
Message 4 of 9
Thanks a lot for your help - I'll give that a shot.
news:71C72862EC2CD0644935F9FB4531888D@in.WebX.maYIadrTaRb...
> > ObjectDbx
> Option Explicit
run
> Dim sPath As String
> oDbx.Open sFullName
> If Err Then
to
> open ***"
> Err.Clear
> Else
> Next
> End If
> Set oLyt = Nothing
> sFileName = Dir$
> Loop
> Set oDbx = Nothing
> End Sub
Message 5 of 9
Can I use Objectdbx in AutoCAD 2002?
is
> advance!
> Kevin Mullinax
Message 6 of 9
Ok, I tried what you suggested, but I'm getting this error message upon
running the routine.
Run-time error (***error-code***)
Problem in loading application.
I have the Object DBX referenced into VBA, so I'm not sure what the problem
is... any ideas?
Thanks again for any help...
Kevin Mullinax
> > ObjectDbx
> Option Explicit
run
> Dim sPath As String
> oDbx.Open sFullName
> If Err Then
to
> open ***"
> Err.Clear
> Else
> Next
> End If
> Set oLyt = Nothing
> sFileName = Dir$
> Loop
> Set oDbx = Nothing
> End Sub
Message 7 of 9
Yes, but you need to register the .dll file. Enter the following at Windows
(not AutoCad) command prompt (hit enter at the end of each line):
c:
cd "program files\autodesk architectural desktop 3"
RegSvr32.exe AxDb15.dll
"Dirkasaurus" wrote in message
news:044911E686E764EF5218CC8B57907EFA@in.WebX.maYIadrTaRb...
another
> is
AutoCAD,
object,
another
> > advance!
> > Kevin Mullinax
Message 8 of 9
You may need to register the objectDBX dll. Enter these lines at the Windows
(not AutoCad) command prompt(hit enter at the end of each line):
c:
news:F719BE447C3464284000F6A47F875A6A@in.WebX.maYIadrTaRb...
problem
> is... any ideas?
> Kevin Mullinax
> > > ObjectDbx
> > Option Explicit
Tools|References
> run
> > Dim sPath As String
> > oDbx.Open sFullName
> > If Err Then
> to
> > open ***"
> > Err.Clear
> > Else
> > Next
> > End If
> > Set oLyt = Nothing
> > sFileName = Dir$
> > Loop
> > Set oDbx = Nothing
> > End Sub
Message 9 of 9
Tony,
I do have the AxDb15.dll file in my AutoCad Map5 directory.. I am assuming
that I can register it the same way? And is there any documentation for
Objectdbx in Map 5. I didn't find any in acad_dev.chm
"Tony Burba" wrote in message
news:393D3A7B125AF62D3117AF573E47FBCA@in.WebX.maYIadrTaRb...
Windows
> c:
VBA?
current
> another
file
> > is
> AutoCAD,
the
> object,
> another
> > > advance!
> > > Kevin Mullinax
