ObjectDBX - Access a Drawing in Use
Hello all,
Info:
AutoCAD Building Systems 2007 on XP
Problem:
I'm currently using ObjectDBX to cycle through an entire project's sheet file directory and grabbing the Layouts collection from each sheet drawing for plotting. All works fine except for when a user has one of the sheets open and the ObjectDBX fails due to a "File in use" or read only drawing status.
Question:
Is there a way to have ObjectDBX access the drawing regardless of the drawing's read status?? This is the last issue to resolve before I can implement this simple routine to my users.
Any ideas, cheats, or solutions would be greatly appreciated.
-Don
Just catch the error, then when it errors with the Unable to open drawing
make a temp copy of it and open the copy, when done delete the copy.
wrote in message news:5451796@discussion.autodesk.com...
Hello all,
Info:
Problem:
status.
Question:
-Don
I had a feeling that would be the only way...
I'm just trying to keep this code as fast as possible since there are som many files...
Thanks tho - I'll adjust the code as you suggest for now...
But hopefully somebody will know a secret way to get this thing to "Read-only"...
-don
