object_vb.net
object_vb.net
Message 1 of 1
object_vb.net
Welcome Forum!
I have a question related to vba of AutoCad, reference your comments. Comments Reference sent to the email address: xanhnhnn280683@gmail.com  thank you.
Questions:( I write mã VBA trong autocad running best, select in objects domain non empty, select the outside of objects domain Empty:)
Sub testboundary
Dim kiemtradoituong As Long, RetPoint As Variant
kiemtradoituong = ThisDrawing.ModelSpace.Count
Dim pt As Variant
pt = ThisDrawing.Utility.GetPoint(, "Select object or enter to finish")
ThisDrawing.SendCommand "-Boundary" & vbCr & pt(0) & "," & pt(1) & vbCr & vbCr
If ThisDrawing.ModelSpace.Count > kiemtradoituong Then
RetPoint = ThisDrawing.Utility.GetPoint(, " non domain Empty ")
Else
RetPoint = ThisDrawing.Utility.GetPoint(, " domain Empty ")
End sub
by vb.net language that supports creating  dynamic library (dll), so I make run some examples vba in autocad.( Address reference: http://through-the-interface.typepad.com/through_the_interface/2011/08/debugging-autocad-net-project...).
when I create file dll by visual tudio 2010 (vb.net) support, the variable (Dim pt As Variant) in vba autocad,  vb.net changed (Dim pt As Object) run vba autocad error, looking for help
Best regards
Xanhnhnn280683
Replies (0)
