Object Reference
Object Reference
Object Reference
I am trying to implement the GetObjectFromName
method of the McadUtility object.
The documentation say that:
"Creating a feature key requires an
McadPart object as a reference."
What is the McadPart object?
What do I put in as the reference?
-Alan Dixon
Hi Alan,
Here is a sample which delete a hole with name "Hole1" and it shows you how
to get McadPartObject reference.
Sub test()
Dim mapp As McadApplication
Dim util As McadUtility
Set mapp =
ThisDrawing.Application.GetInterfaceObject("Mcad.Application")
Set util = mapp.ActiveDocument.Utility
Dim Pick As McadPick
Set Pick = util.Pick("Select Part", mcPart)
Dim mpart As McadPart
Set mpart = util.GetObjectFromPick(Pick)
Dim holef As McadFeature
Set holef = util.GetObjectFromName("Hole1", mcFeature, mpart)
holef.Delete
End Sub
Cheers,
Ishwar Nagwani
DCG, Autodesk
Alan B. C. Dixon wrote in message
news:381F5907.648D85B6@psnet.com...
> -Alan Dixon
Hello Ishwar,
Thanks for the excellent example. Its just what I needed,
and does the job I needed it to do. I really appreciate your
response to my question.
-Alan
Ishwar Nagwani wrote:
> Hi Alan,
> Sub test()
> Set mapp =
> holef.Delete
> End Sub
> Cheers,
> Ishwar Nagwani
> DCG, Autodesk
> > -Alan Dixon
