object re-selection
object re-selection
Message 1 of 17
object re-selection
This is probably staring me in the face, but ...
I have a routine that prompts the user for an entity, and if this entity is
not a closed polyline, then it attempts to make it one for the user. All of
this works fine, my problem is in the retest. I can't seem to reselect the
(now a polyline) entity within the code (i.e. without user interaction). I
obtain the original entity with ThisDrawing.Utility.GetEntity and then
create the polyline with sendcommand.
Any help would be appreciated.
Replies (16)
Message 2 of 17
if this is exactly what you're doing...
> I have a routine that prompts the user for *an* entity, and if this entity
is
> not a closed polyline, then it attempts to make *it* one for the user.
meaning you're only dealing with one entity at a time, why are you using
sendcommand to create the pline.
if you're using vba, why not use vba?
if it's already a pline and you just want to close it, you just have to set
it's closed property
if it's not a pline, you could create a pline with AddLightweightpolyline
in which case you'd have the newly created object available
on the other hand if you prefer sendcommand, then (entlast) should give you
the just added pline (if it's visible in your current display window)
"Nathan Guill" wrote in message
news:D5E4A8C60E0074F0EC38BF7722C37DC0@in.WebX.maYIadrTaRb...
is
of
the
Message 3 of 17
If you just created an entity, it will be the last in the db. Just like you
can use the Last argument to any selection prompt in acad, the selection set
object has this option too.
Dim ss As AcadSelectionSet
ss.Select acSelectionSetLast
Ed
is
of
the
Message 4 of 17
What's happening is that the user selects an entity, if this entity is a
LWPolyline, then it checks to see if it's closed. If the pline is not
closed, or the entity is not a pline, then it attamps to "Join All" the
entities connected to it to see if that creates a closed pline. IF so, then
I can continue with the rest of my routine, which is to revolve the closed
pline to get the volume and eventually the weight of the cross section the
user first selected.
"Mark Propst" wrote in message
news:51AFF249F18808087279B396951C3454@in.WebX.maYIadrTaRb...
entity
> is
set
you
> is
All
> of
> the
I
Message 5 of 17
Basically, I just "joined all" the connected entities to the one the user
selected to create the pline.
select doesn't return anything, though.
Below is the code I have so far. To set it up, just create a rectangle (not
crossing the X plane) and explode it.
Function GetWeight()
Dim basePnt As Variant
Dim centerObj As AcadObject
Dim strCenter As String
Dim strWeight As String
Dim Response As VbMsgBoxResult
Dim returnObj As AcadObject
ThisDrawing.Utility.InitializeUserInput 1, "Yes No"
' Prompt the user to input any of the keywords.
strWeight = ThisDrawing.Utility.GetKeyword("Are you looking for the weight
(Yes No):")
ThisDrawing.Utility.InitializeUserInput 8
Start:
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select cross-section
for calculation: "
If Not TypeOf returnObj Is AcadLWPolyline Then
If Len(returnObj.Handle) = 0 Then
VBA.MsgBox "You must select an entity to continue.", vbExclamation +
vbOKOnly, _
"No Entity"
GoTo Start
Response = VBA.MsgBox("This entity is not a polyline," & VBA.vbCrLf & _
"Should I try and make it one?", vbQuestion + vbYesNo, "Wrong Entity
Type")
If Response = vbNo Then End
ThisDrawing.SendCommand "pedit" & VBA.vbCr & Ent2lspEnt(returnObj) & _
VBA.vbCr & "Yes" & VBA.vbCr & "Join" & VBA.vbCr & "All" & VBA.vbCr &
VBA.vbCr & _
VBA.vbCr
'returnObj = ThisDrawing.SendCommand("(entlast)")
VBA.MsgBox "This entity cannot be made into a Polyline.",
vbExclamation + vbOKOnly, _
"Wrong Entity Type"
End
ThisDrawing.Utility.InitializeUserInput 1, "Xaxis Yaxis Object"
strCenter = ThisDrawing.Utility.GetKeyword("Select center line (Xaxis
Yaxis Object):")
Select Case strCenter
Case "Xaxis"
ThisDrawing.SendCommand "undo mark revolve " & _
FMI_Utilities.FMI.Ent2lspEnt(returnObj) & " X 360 "
Case "Yaxis"
Case "Object"
ThisDrawing.Utility.GetEntity centerObj, basePnt, "Select center line
object: "
Case Else
End
End Select
If strWeight = "Yes" Then
VBA.MsgBox "This part weighs " & (returnObj.Volume * 0.297) & " in Inco
718"
Else
VBA.MsgBox "The volume of this part is " & returnObj.Volume
End Function
Public Function Ent2lspEnt(entObj As AcadEntity) As String
'Designed to work with SendCommand, which can't pass objects.
'This gets an objects handle and converts it to a string
'of lisp commands that returns an entity name when run in SendCommand.
Dim entHandle As String
entHandle = entObj.Handle
Ent2lspEnt = "(handent " & Chr(34) & entHandle & Chr(34) & ")"
End Function
"Ed Jobe" wrote in message
news:1FE06E944FA26D430C181796A59B2F14@in.WebX.maYIadrTaRb...
you
set
> Ed
> is
All
> of
> the
I
Message 6 of 17
I'm leaving pretty quick, so I don't have time to give more detail, but
SendCommand is asyncronous. It is completing after you look for the last
ent. Also, you Dim'ed ss, but didn't create an ss. You might also search
this ng on how to make a poly line. That's been discussed before. Get that
info and go with Mark's suggestion to create the poly via ActiveX. Then you
can forget the ss route and SendCommand.
Ed
news:588D9043A9B0E48EB7EB8D4175E4E7CB@in.WebX.maYIadrTaRb...
(not
weight
> (Yes No):")
> Start:
> for calculation: "
> vbOKOnly, _
> "No Entity"
> GoTo Start
> End If
_
> Type")
> VBA.vbCr & _
> VBA.vbCr
> "Wrong Entity Type"
> End
> End If
> End If
> Yaxis Object):")
> Case "Xaxis"
> Case "Yaxis"
> Case "Object"
line
> object: "
> Case Else
> End
> End Select
Inco
> 718"
> Else
> End If
> End Function
> End Function
> you
> set
> > Ed
entity
> > is
> All
> > of
reselect
> > the
interaction).
> I
Message 7 of 17
Something else just occured to me. At the point you check for a pline, you
only have one ent. You can't make a closed pline with one ent. You'll have
to rethink your program logic. Do you offer to make a pline at all, or just
restrict input to plines? If yes to convert to plines, you'll have to
reselect to allow multiple ents.
Ed
news:4386729F4AA191283425321602C138FA@in.WebX.maYIadrTaRb...
you
> Ed
user
> (not
> weight
> > (Yes No):")
> > Start:
cross-section
> > for calculation: "
> > vbOKOnly, _
> > "No Entity"
> > GoTo Start
> > End If
> _
Entity
> > Type")
_
> > VBA.vbCr & _
> > VBA.vbCr
> > "Wrong Entity Type"
> > End
> > End If
> > End If
> > Yaxis Object):")
> > Case "Xaxis"
> > Case "Yaxis"
> > Case "Object"
> line
> > object: "
> > Case Else
> > End
> > End Select
> Inco
> > 718"
> > Else
> > End If
> > End Function
> > End Function
like
> > you
selection
> > set
> > > Ed
> entity
> > > is
> > All
> > > of
> reselect
> > > the
> interaction).
> > I
then
Message 8 of 17
I have show a form in modless and AutoCAD always get the focus unless I
click the form.
I can not input anything to the textbox in the form.
How can I deal with it?
Thank you very much!
From Afanto.
Message 9 of 17
does this help?
Subject: Re: Working with a modeless dialog
Date: Wednesday, February 06, 2002 3:50 PM
Go to the Toolbar, right click, click Additional Controls then check
AcFocusCtrl Class.
No add the newly added control from the toolbar to your form.
In the Initialize area add
Me.AcFocusCtrl1.KeepFocus = true
now the textbox keeps its focus.
Thanks to Rich Binning for noting this.
"Afanto" wrote in message
news:708533350141A0A67175751F637EA002@in.WebX.maYIadrTaRb...
I
> click the form.
> From Afanto.
Message 10 of 17
Thank you very much.
Afanto
Message 11 of 17
You're right. I only have one entity when I first test for a pline, hence
the "join all" operation in the sendcommand. Basically, the entity the user
will be selecting will be part of a cross-section of a ring. If it's a
closed polyline then it revolves this section and gets a weight, otherwise,
it attemps to join all connected lines into a closed polyline then gets the
weight. That's why I think I have to use the sendcommand. Do you know of
another way to join all connected lines together with only one entity
selected?
news:D1FACECEECA8980641C179038F681598@in.WebX.maYIadrTaRb...
just
> Ed
that
> you
> > Ed
> user
rectangle
> > (not
> > weight
> > > (Yes No):")
> > > Start:
> cross-section
> > > for calculation: "
vbExclamation
> > > vbOKOnly, _
> > > "No Entity"
> > > GoTo Start
> > > End If
VBA.vbCrLf
> > _
> Entity
> > > Type")
> _
VBA.vbCr
> > > VBA.vbCr & _
> > > VBA.vbCr
> > > "Wrong Entity Type"
> > > End
> > > End If
> > > End If
(Xaxis
> > > Yaxis Object):")
> > > Case "Xaxis"
> > > Case "Yaxis"
> > > Case "Object"
> > line
> > > object: "
> > > Case Else
> > > End
> > > End Select
> > Inco
> > > 718"
> > > Else
> > > End If
> > > End Function
SendCommand.
> > > End Function
> like
> > > you
> selection
> > > set
> > > > Ed
> > entity
> > > > is
user.
> > > All
> > > > of
> > reselect
> > > > the
> > interaction).
> > > I
> then
Message 12 of 17
The PEDIT command joins connected lines, but it doesn't magically find them
for you, you have to select them. If you are going to offer this feature in
your code, at the point you determine that the single ent they selected is
not a pline (assuming its a line or arc), then you need to prompt the user
to select the rest of the ents to perform the join on. Use their geometry
info to construct a pline via ActiveX. If you want just get your command
working for now, only allow them to select plines and quit if they want to
perform the join themselves. You can add the join functionality after you
get the bulk of the command working. Check this ng for code on how to make a
pline.
Ed
news:65471D62C2CFC09F5007D338D1F4FAB7@in.WebX.maYIadrTaRb...
user
otherwise,
the
> selected?
you
have
> just
> > Ed
but
last
search
> that
Then
> > you
> > > Ed
> > user
> rectangle
> > > (not
the
> > > weight
> > > > (Yes No):")
> > > > Start:
> > cross-section
> > > > for calculation: "
> vbExclamation
> > > > vbOKOnly, _
> > > > "No Entity"
> > > > GoTo Start
> > > > End If
> VBA.vbCrLf
> > > _
> > Entity
> > > > Type")
> > _
> VBA.vbCr
> > > > VBA.vbCr & _
> > > > VBA.vbCr
> > > > "Wrong Entity Type"
> > > > End
> > > > End If
> > > > End If
> (Xaxis
> > > > Yaxis Object):")
> > > > Case "Xaxis"
> > > > Case "Yaxis"
> > > > Case "Object"
center
> > > line
> > > > object: "
> > > > Case Else
> > > > End
> > > > End Select
in
> > > Inco
> > > > 718"
> > > > Else
> > > > End If
> > > > End Function
> SendCommand.
> > > > End Function
> > like
> > > > you
> > selection
> > > > set
> > > > > Ed
this
> > > entity
> > > > > is
> user.
> > > > All
> > > > > of
> > > reselect
> > > > > the
> > > interaction).
> > > > I
and
> > then
Message 13 of 17
I'm sorry to tell you, but if you type PEDIT, select a line, tell it to turn
it into a pline, then select join and then type in all, any lines connected
to that first line you selected will then be joined to that line. I know
this works as I do this many times a day. I NEVER have to select more than
one line as I tell it to join ALL. Since ONLY the entities that share some
common point can be joined, autocad only joins those entities. Don't
beleive me... TRY IT.
news:2690302D83BEE74598E4956B343E9FEA@in.WebX.maYIadrTaRb...
them
in
a
> pline.
> Ed
hence
> user
> otherwise,
> the
of
> > selected?
> you
> have
> > just
> > > Ed
> but
> last
> search
Get
> > that
> Then
> > > you
> > > > Ed
the
> > > user
> > rectangle
> > > > (not
> the
> > > > weight
> > > > > (Yes No):")
> > > > > Start:
> > > cross-section
> > > > > for calculation: "
> > vbExclamation
> > > > > vbOKOnly, _
> > > > > "No Entity"
> > > > > GoTo Start
> > > > > End If
> > VBA.vbCrLf
> > > > _
"Wrong
> > > Entity
> > > > > Type")
> > > _
> > VBA.vbCr
> > > > > VBA.vbCr & _
> > > > > VBA.vbCr
> > > > > "Wrong Entity Type"
> > > > > End
> > > > > End If
> > > > > End If
> > (Xaxis
> > > > > Yaxis Object):")
> > > > > Case "Xaxis"
> > > > > Case "Yaxis"
> > > > > Case "Object"
> center
> > > > line
> > > > > object: "
> > > > > Case Else
> > > > > End
> > > > > End Select
> in
> > > > Inco
> > > > > 718"
> > > > > Else
> > > > > End If
> > > > > End Function
> > SendCommand.
> > > > > End Function
Just
> > > like
> > > > > you
> > > selection
> > > > > set
> > > > > > Ed
> this
> > > > entity
> > > > > > is
> > user.
> > > > > All
> > > > > > of
> > > > reselect
> > > > > > the
> > > > interaction).
> > > > > I
> and
> > > then
Message 14 of 17
That's true. I forgot they added that, it didn't used to do that. I havn't
used it in a while. But in the context of this discussion, you still had go
through the extra step of telling it to add more ents. The command just
filtered out all the lines that connect to it. You need to duplicate that
using ActiveX if you aren't going to use SendCommand.
Ed
news:BF22288999FE458D9E3773E64A58E215@in.WebX.maYIadrTaRb...
turn
connected
than
some
> them
> in
is
user
geometry
to
you
make
> a
> > pline.
> > Ed
> hence
the
> > user
a
> > otherwise,
gets
> > the
know
> of
> > > selected?
pline,
> > you
You'll
> > have
or
> > > just
to
> > > > Ed
detail,
> > but
the
> > last
> > search
> Get
> > > that
> > Then
> > > > you
> > > > > Ed
> the
> > > > user
> > > rectangle
> > > > > (not
for
> > the
> > > > > weight
> > > > > > (Yes No):")
> > > > > > Start:
> > > > cross-section
> > > > > > for calculation: "
> > > vbExclamation
> > > > > > vbOKOnly, _
> > > > > > "No Entity"
> > > > > > GoTo Start
> > > > > > End If
> > > VBA.vbCrLf
> > > > > _
> "Wrong
> > > > Entity
> > > > > > Type")
> > > > _
> > > VBA.vbCr
> > > > > > VBA.vbCr & _
> > > > > > VBA.vbCr
> > > > > > "Wrong Entity Type"
> > > > > > End
> > > > > > End If
> > > > > > End If
Object"
> > > (Xaxis
> > > > > > Yaxis Object):")
> > > > > > Case "Xaxis"
> > > > > > Case "Yaxis"
> > > > > > Case "Object"
> > center
> > > > > line
> > > > > > object: "
> > > > > > Case Else
> > > > > > End
> > > > > > End Select
> > in
> > > > > Inco
> > > > > > 718"
> > > > > > Else
> > > > > > End If
> > > > > > End Function
> > > SendCommand.
> > > > > > End Function
> Just
> > > > like
> > > > > > you
> > > > selection
> > > > > > set
> > > > > > > Ed
> > this
> > > > > entity
> > > > > > > is
the
> > > user.
> > > > > > All
> > > > > > > of
to
> > > > > reselect
> > > > > > > the
> > > > > interaction).
> > > > > > I
> > and
> > > > then
Message 15 of 17
Okay, how do I do that? I know how I can add the entities that share a
starting or ending point with the original entity, but how do I mimic the
"join all" function of PEDIT in ActiveX without creating an infinate loop?
I searched for something already written that might help, but I still don't
understand how to do that.
Am I making sense? Sorry if I'm not.
news:6A3B51A14F1A8A939FD1071E9613423A@in.WebX.maYIadrTaRb...
go
> Ed
> turn
> connected
know
> than
> some
> > them
feature
> > in
selected
> is
> user
> geometry
command
want
> to
> you
> make
> > a
> > > pline.
> > > Ed
> > hence
> the
> > > user
it's
> a
> > > otherwise,
> gets
> > > the
> know
> > of
entity
> > > > selected?
> pline,
> > > you
> You'll
> > > have
all,
> or
> > > > just
> to
> > > > > Ed
> detail,
> > > but
> the
> > > last
also
> > > search
before.
> > Get
> > > > that
ActiveX.
> > > Then
> > > > > you
> > > > > > Ed
one
> > the
> > > > > user
> > > > rectangle
> > > > > > (not
> for
> > > the
> > > > > > weight
> > > > > > > (Yes No):")
> > > > > > > Start:
> > > > > cross-section
> > > > > > > for calculation: "
> > > > vbExclamation
> > > > > > > vbOKOnly, _
> > > > > > > "No Entity"
> > > > > > > GoTo Start
> > > > > > > End If
> > > > VBA.vbCrLf
> > > > > > _
> > "Wrong
> > > > > Entity
> > > > > > > Type")
> > > > > _
> > > > VBA.vbCr
> > > > > > > VBA.vbCr & _
> > > > > > > VBA.vbCr
Polyline.",
> > > > > > > "Wrong Entity Type"
> > > > > > > End
> > > > > > > End If
> > > > > > > End If
> Object"
line
> > > > (Xaxis
> > > > > > > Yaxis Object):")
> > > > > > > Case "Xaxis"
> > > > > > > Case "Yaxis"
> > > > > > > Case "Object"
"Select
> > > center
> > > > > > line
> > > > > > > object: "
> > > > > > > Case Else
> > > > > > > End
> > > > > > > End Select
0.297)
> > > in
> > > > > > Inco
> > > > > > > 718"
> > > > > > > Else
returnObj.Volume
> > > > > > > End If
> > > > > > > End Function
objects.
> > > > SendCommand.
> > > > > > > End Function
db.
> > Just
> > > > > like
> > > > > > > you
the
> > > > > selection
> > > > > > > set
> > > > > > > > Ed
if
> > > this
> > > > > > entity
> > > > > > > > is
> the
> > > > user.
> > > > > > > All
> > > > > > > > of
seem
> to
> > > > > > reselect
> > > > > > > > the
> > > > > > interaction).
> > > > > > > I
> > > and
> > > > > then
Message 16 of 17
I don't have time to do a thorough search for you, but this should get you
started. http://tinyurl.com/ynmh. Take note of the array for the vertices.
It only uses two points. You just have to add more vertices. Use google.com
to seach this ng or use the search feature in the web version. I found this
with just "polyline" as the keyword.
Ed
news:2C0E7310104B18878321281F927837EF@in.WebX.maYIadrTaRb...
don't
havn't
> go
that
> > Ed
to
> > turn
> > connected
> know
> > than
> > some
find
> > > them
> feature
> > > in
> selected
> > is
the
> > user
> > geometry
> command
> want
> > to
after
> > you
to
> > make
> > > a
> > > > pline.
> > > > Ed
pline,
> > > hence
entity
> > the
> > > > user
> it's
> > a
> > > > otherwise,
> > gets
> > > > the
> > know
> > > of
> entity
> > > > > selected?
> > pline,
> > > > you
> > You'll
> > > > have
> all,
> > or
> > > > > just
have
> > to
> > > > > > Ed
> > detail,
> > > > but
for
> > the
> > > > last
> also
> > > > search
> before.
> > > Get
> > > > > that
> ActiveX.
> > > > Then
> > > > > > you
> > > > > > > Ed
> one
> > > the
> > > > > > user
a
> > > > > rectangle
> > > > > > > (not
looking
> > for
> > > > the
> > > > > > > weight
> > > > > > > > (Yes No):")
> > > > > > > > Start:
> > > > > > cross-section
> > > > > > > > for calculation: "
> > > > > vbExclamation
> > > > > > > > vbOKOnly, _
> > > > > > > > "No Entity"
> > > > > > > > GoTo Start
> > > > > > > > End If
> > > > > VBA.vbCrLf
> > > > > > > _
> > > "Wrong
> > > > > > Entity
> > > > > > > > Type")
> > > > > > _
"All"
> > > > > VBA.vbCr
> > > > > > > > VBA.vbCr & _
> > > > > > > > VBA.vbCr
> Polyline.",
> > > > > > > > "Wrong Entity Type"
> > > > > > > > End
> > > > > > > > End If
> > > > > > > > End If
> > Object"
> line
> > > > > (Xaxis
> > > > > > > > Yaxis Object):")
> > > > > > > > Case "Xaxis"
> > > > > > > > Case "Yaxis"
> > > > > > > > Case "Object"
> "Select
> > > > center
> > > > > > > line
> > > > > > > > object: "
> > > > > > > > Case Else
> > > > > > > > End
> > > > > > > > End Select
> 0.297)
> > > > in
> > > > > > > Inco
> > > > > > > > 718"
> > > > > > > > Else
> returnObj.Volume
> > > > > > > > End If
> > > > > > > > End Function
> objects.
> > > > > SendCommand.
> > > > > > > > End Function
> db.
> > > Just
> > > > > > like
> > > > > > > > you
> the
> > > > > > selection
> > > > > > > > set
> > > > > > > > > Ed
and
> if
> > > > this
> > > > > > > entity
> > > > > > > > > is
for
> > the
> > > > > user.
> > > > > > > > All
> > > > > > > > > of
> seem
> > to
> > > > > > > reselect
> > > > > > > > > the
user
> > > > > > > interaction).
> > > > > > > > I
> > > > and
> > > > > > then
Message 17 of 17
Nathan,
If you put a generous pause after the sendcommand, does it give ACAD time
to create the pline? It's clunky, but if you've already got code done and
you're going to be the main one using it, and it doesn't have to be
bulletproof....
James
VBA.vbCr & _
VBA.vbCr
'don't run this within 5 seconds of midnite, or you're in trouble....
Dim endt As Double, wait As Double
wait = 5 'seconds
endt = Timer + wait
Do Until Timer > endt: DoEvents: Loop
