_Not so easy ADO question...
serge
serge
I can connect to an ACCESS-file from within ACAD without any problem ... I do use ADO for this with a connection string and a SQL-statement for accessing a Table ... Here's my question: Has anybody has a programm-example how to check if a certain table exist in de mdb-file, if not how to copy another existing Table in a new one ... Thanks for any ideas ... SMD
DEVIDTS Serge, CAD Consultant
http://www.CADdICT.be
To get the tables in the database, use the OpenSchema method of the
Connection object with the adSchemTables parameter. See
How to proceed if the table you want isn't there depends on what you
want to do with that table. Probably the easiest thing to do is to
create a view (if the view isn't there already .. use the OpenSchema
method with the adSchemaViews parameter). (Access calls views
"queries"). Just execute the SQL statement "create view
as select * from ". Then the view can be treated as if it
were a table. Changes to the records in the view will appear in the
underlying table.
jrf
Member of the Autodesk Discussion Forum Moderator Program
Please do not email questions unless you wish to hire my services
problem
exist
Whoops, adSchemaTables parameter.
jrf
serge
Hi Jon ...
Iterating through the Tables is no problem anymore, but copying a existing table does NOT work with a "CREATE VIEW..."-SQL, since ACCESS is not supporting this SQL-statement ... I wrote In the access-file a VBA-macro to copy a existing table, this works well, how can I trigger this Macro from within ACAD-VBA ? ... Any other solutions to copy an existing table in an Access file are also aprreciated ... Thanks, SMD ...
Arggh! Bill strikes again! How can they not support "create view
I don't know of any way to trigger the VBA macro; it's out-of-scope
for AutoCAD VBA and the driver that interfaces with the database.
I know that Access supports "create table ..." (and "drop table ...");
you could create the table and then do "update ,
set . = ., . =
If you know the name of the table that contains the information you
need, why do you insist on accessing that information under another
table name?
jrf
> Hi Jon ...
As Jon suggested you can use ADO to create a table as needed, I don't know
off hand if ADO supports any method for copying an existing table. If you do
write an Access macro then you can run it from your VB/VBA routine by
setting a reference to the Microsoft Access type library in your project
then use the following...
Private Sub RunProc()
Application.Run "YourAccessMacro"
End Sub
Obviously Application must be a valid reference to the Access Application
object and "YourAccessMacro" (as a string) must be the name of a public sub
defined in the current access database.
Jacob Dinardi
"smd" wrote in message
news:f0c8649.2@WebX.maYIadrTaRb...
> Hi Jon ...
