Non associative hatches not returning object for GetLoopAt method
I have a program that gets a selection of hatches and writes information about them to a list in excel. The point is to generate a list of parts and create them in inventor from the information I'm generating in autocad. From what I can tell my difficulty is coming from non associative hatches, where the GetLoopMethod doesn't return an object. I'm looking at either a way to find the boundaries for each loop of the hatch (I need its total size and location) or else a way to redefine the boundaries on the fly and make it associative.
Function ExportHatches(oSheet As Object) 'Declaring Excel Row Dim Row As Integer 'Declaring holder variables for individual hatch values Dim HatchLStart As Double Dim HatchLEnd As Double Dim HatchWStart As Double Dim HatchWEnd As Double Dim Length As Double Dim Width As Double 'Declaring Hatch holder Dim oHatch As AcadHatch 'Declaring Selection Set Variables Dim SSObj As AcadSelectionSet Dim FilterType(0) As Integer Dim FilterData(0) As Variant 'Declaring points Dim EndPoint As Variant Dim LoopObjs As Variant Dim StartPoint As Variant Dim UpdatedPoint As Variant Dim UpdatedStartPoint As Variant Dim UpdatedEndPoint As Variant 'Initializing Variables Row = 1 FilterType(0) = 0 FilterData(0) = "Hatch" Set SSObj = ThisDrawing.ActiveSelectionSet SSObj.Clear SSObj.SelectOnScreen FilterType, FilterData 'Iterate Through Selection Set and write out data With oSheet .Cells.Clear For Each oHatch In SSObj MsgBox (oHatch.AssociativeHatch) If UCase(oHatch.PatternName) = "ANSI31" Or UCase(oHatch.PatternName) = "ANSI37" Or UCase(oHatch.PatternName) = "HONEY" Then oHatch.GetBoundingBox StartPoint, EndPoint For i = 0 To oHatch.NumberOfLoops - 1 'Set Hatch initialization values HatchLStart = 100000 HatchLEnd = -100000 HatchWStart = 100000 HatchWEnd = -100000 oHatch.GetLoopAt i, LoopObjs If IsObject(LoopObjs) Then For j = LBound(LoopObjs) To UBound(LoopObjs) LoopObjs(j).GetBoundingBox StartPoint, EndPoint UpdatedStartPoint = ThisDrawing.Utility.TranslateCoordinates(StartPoint, acWorld, acUCS, False) UpdatedEndPoint = ThisDrawing.Utility.TranslateCoordinates(EndPoint, acWorld, acUCS, False) 'Check that values are lowest and If UpdatedStartPoint(0) < HatchLStart Then HatchLStart = UpdatedStartPoint(0) If UpdatedEndPoint(0) > HatchLEnd Then HatchLEnd = UpdatedEndPoint(0) If UpdatedStartPoint(1) < HatchWStart Then HatchWStart = UpdatedStartPoint(1) If UpdatedEndPoint(1) > HatchWEnd Then HatchWEnd = UpdatedEndPoint(1) Next Length = Abs(HatchLEnd - HatchLStart) Width = Abs(HatchWEnd - HatchWStart) If UCase(oHatch.PatternName) = "ANSI31" Then .Cells(Row, 1) = "Surface" If UCase(oHatch.PatternName) = "ANSI37" Then .Cells(Row, 1) = "Flush" If UCase(oHatch.PatternName) = "HONEY" Then .Cells(Row, 1) = "Bottom" .Cells(Row, 2) = Length .Cells(Row, 3) = Width .Cells(Row, 4) = HatchLStart .Cells(Row, 5) = HatchWStart Row = Row + 1 End If Next End If Next End With End Function
