Newbie question about convertpstyles
Hi
I have lots of drawings set up with STB. I wanna convert them all into using CTB.
I tried using a script, and it works fine as long as all the files i have selected is set up with STB. But when it found files that allready had CTB, scriptpro used almost a minute before it quit AutoCAD and moved on to the next drawing...
So i guess a small vb program will solve this, so that all the files with CTB files allready are ignored.
Or maybe a way to just change the read only PSTYLEMODE variable...
Hope some of you can help me with this issue.
Dean
No VBA program is needed. In the script file, first examine the PStyleMode
system variable and execute the command only if it is equal to 0.
(if (= (getvar "PStyleMode") 0) (command "._ConvertPStyles"))
R. Robert Bell
wrote in message news:5312031@discussion.autodesk.com...
Hi
CTB.
next drawing...
Dean
You're going backwards.
Hi
CTB.
next drawing...
Dean
Hi
thanks alot. knew it was easy.
much appriciated
dean
Well, _I_ didn't want to say that... glad you did! ;^)
R. Robert Bell
"Tony Burba" wrote in message
news:5313237@discussion.autodesk.com...
